Application Users
Answered Question
Jun 30th, 2010
  • Silver, 250 points or more
Is it good practice to have different users set up for each different CTI RP?
A UCCX system is used by two or more different groups - Sales, Accounts, IT each with their own scripts and CT RP`s for access numbers. Would it be best to create an application user for each "call centre" to separate the different groups and assicate the differnt CTI RP`s and ports to each user or just use a single user and associate all the CTI RP`s and Ports to the one user and separate the scripts in UCCX?
thanks
Correct Answer by Aaron Harrison about 6 years 11 months ago
The bottom line is that you can't do this with UCCX - there is a single RM JTAPI user, and a single JTAPI user (per server in the cluster).
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 06/30/2010 - 03:21
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
