Switch Access tow Data Vlan at same time
Answered Question
Jun 30th, 2010
how can i configure cisco 3560 switch port to be ember of 2 data vlan at the same time :
bellow is the switch port configuration:
interface GigabitEthernet0/1
switchport access vlan 19
switchport mode access
switchport voice vlan 18
switchport port-security maximum 3
switchport port-security violation protect
switchport port-security aging type inactivity
storm-control broadcast level 1.00
spanning-tree portfast
spanning-tree bpduguard enable
end
if you noticed here the switch port is accessing VLAN 19 which is data VLAN , and its Voice VLAN is 18
how can i make access another Data vlan eg: 11
please help me with the same.
Correct Answer by Leo Laohoo about 6 years 10 months ago
If the port is set to a trunk port, it is a member to all the VLANs specified.
Overall Rating: 5 (1 ratings)
shivlu jain Wed, 06/30/2010 - 03:42
  • Silver, 250 points or more
On single port could only be part of access vlan. If you want to pass multiple data vlans on that port then you need to configure that port as trunk port.
regards
Shivlu Jain
http://www.mplsvpn.info
Leo Laohoo Wed, 06/30/2010 - 04:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Make it a dot1q trunk port and allow VLANs 11, 18 and 19.
Muzzamil Hussain Wed, 06/30/2010 - 04:46
thanks for your replay, Butwhen configured the same i was not able to make the switch port member of VLAN 19 and 11 as well
bellow is the configuration :
Switch(config)#int g0/1
Switch(config-if)#switchport trunk encapsulation dot1q
Switch(config-if)#switchport trunk allowed vlan all ( i Just Allwed All VLAN )
Switch(config-if)#do sh run int g0/1
Building configuration...
Current configuration : 397 bytes
!interface GigabitEthernet0/1
Switch(config-if)#switchport access vlan ?
  <1-4094>  VLAN ID of the VLAN when this port is in access mode
  dynamic   When in access mode, this interfaces VLAN is controlled by VMPS
Switch(config-if)#switchport access vlan 19 11
% Invalid input detected at '^' marker.
Please advice
Correct Answer
Leo Laohoo Wed, 06/30/2010 - 04:57
  • Hall of Fame,
    2017 LAN, Wireless
Muzzamil Hussain Wed, 06/30/2010 - 14:09
so i can connect an end host to the port ? but IP address it will get , if you noticed we can make the switch port access only one VLAn even if we configured it as a trunk port ?
Leo Laohoo Wed, 06/30/2010 - 15:12
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
Yes.  It's possible.
If you  want the port to access only one (1) VLAN then Best Practice is to configure the ports as access.
Related Content
