CSM error when deploy on cisco router
Jun 30th, 2010
i have csm 3.2.2 , and added cisco router to the csm , and discovered policied , when i want to daploy any configuration , during validation i get the above error , that need to be fixed in order to continue the deployment
Panos Kampanakis Wed, 07/07/2010 - 10:48
You are probably configure PPP on the router victual interface in CSM.
Make sure you remove that and then it should move forward.
I hope it helps.
