Cisco 6509 Mac-add
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Hi all
I have 1 problem with my 6509, ware buy I can still see my mac-add on the port, witch is port 0/9 I have run sh cam and on the device and I still can see the mac is still there event the physical connection has been plug out. I have try to reset the port, to take out the configuration but error massage “part of the routing appear. I have try to reset the port but the mac-add still there. Can any one advice me what should I do on this issue.
