unable to open a particular vpn site through ADSL cisco router 1841 & 877
Jun 30th, 2010
Hi Guys,
My customer is facing a  strange problem..
The topology is quite simple..
ADSL connection ---->Cisco router 1841--->switch
The people are able to browse no problem with that. But there is a particular vpn which is connected to US. ( sabre VPN works on SSL)
It doesnt work on maximum desktops with windows xp/visata.
but 2 machines its is working(they are windows xp)
While opening the vpn site (my.sabre.com) the site is getting stuck in loading the JAVA. This problem is seen only while they connect
to cisco 1841 or 877 series router but not when they connect to ISP supplied router (which is a baby router)
I tried to adjust the tcp-mss, mtu value in the router to 1500, 1492,1462..even I tried to set the MTU in the system registry to 1300 also
but no luck..
Even I tried to change the IOS version to 12.4-24T3 in both the routers..still no luck.
debugging is also not showing anything but I got error of "packet too big - 1522" so after that I chaange the MTU sizes..(still no luck)
Can you guys please help me troubleshooting this issue..
Jvalin
vladimirsaltao Wed, 06/30/2010 - 08:09
the "ip tcp adjust-mss" should have done the job, can you do a capture  some of  the packets for those host to see if the mss is being correctly set
