06-30-2010 06:21 AM - edited 03-19-2019 01:10 AM
hello
this is the snario :
call that transfer from call handler (unity connection) to hunt pilot(cucm) and back to call handler(unity connection) to specified vm
is not working.
i get the basic vm all the time insted of the greeting of the person i transfer to
helpppppppppp
thanks
shoham
06-30-2010 08:52 AM
Hi Shoham,
Can you explain this portion (with examples if possible);
back to call handler (unity connection) to specified vm fails
Cheers!
Rob
06-30-2010 09:35 AM
My guess is he wants to go to the VM from one of the line group members, but since he's dialing the hunt pilot DN you're trying to reach the matching DN in unity.
You can define the DN from HP as alternate extension for subscriber or create a call routing rule to achieve the same.
An example of what you dial, what happens, and what you want to happen would clear things up
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
