Cisco 9971 IP Phone Registration Issue
Jun 30th, 2010
Dear All,
I have Cisco 9971 phones which i am trying to install with CUCM 7.1(3). As per datasheet it should be supported.
Initially i could not even see it in the list of devices on the CUCM .Than i installed the device patch from Cisco and list started showing me on the device list.
But still it is not registering.
I was reading on web that you need to upgrade the phones to 7.1(3b)su2.....is it true?
Also the phones comes with SIP firmware...does the installation process is same for SIP or SCCP?
Can someone guide me how to upgrade the CUCM version and the correct firmware to use?
Rob Huffman Wed, 06/30/2010 - 06:36
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nomy,
You will need at least 7.1(3a)su1 but I really think moving to 7.1(3b)SU2
would be an excellent call due to numerous bug fixes
Cisco Unified IP Phone 8900 and 9900 Series
Before using the Cisco Unified IP Phone with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Note You can install Cisco Unified Communications Manager 7.1(3) or 7.1(3a). After you install one of these releases, you must install Cisco Unified Communications Manager*** 7.1(3a)su1. ***
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713a.html#wp1754557
Cheers!
Rob
nomykhan Wed, 06/30/2010 - 06:47
Dear Rob
Thanks for your quick reply.
Can you please let me know how to upgrade my 7.1(3) to 7.1(3)su2?
is the patch available to download from cisco?
CAn u send me the link with the procedure to upgrade?
Rob Huffman Wed, 06/30/2010 - 07:38
  • Hall of Fame,
    Founding Member
Hi Nomy,
From the Software Downloads Page;
Voice and Unified Communications >IP Telephony> Call Control >Cisco Unified Communications Manager (CallManager)>
Cisco Unified Communications Manager Version 7.1 >Unified Communications Manager Updates >7.1(3b)SU2
Installation Instructions
http://www.cisco.com/web/software/282074295/31799/cucm-readme-713bsu2.pdf
Software Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
