06-30-2010 08:31 AM - edited 03-21-2019 02:44 AM
The UC540 is setup in PBX mode but the FXO lines are directed to the CO lines. Each phone has the CO lines as buttons. When someone picks up a call, the transfer softkey is greyed out. The transfer to vm key works fine. Is there any way to make this work?
11-18-2010 09:16 AM
This problem is still not resolved.
Here is some more information. When you make an outgoing call, the transfer key is an available option.
11-18-2010 12:23 PM
Are your CO line dn's configured as dual-line?
Have you also verified the ephone-templates are correctly configured?
If so, you might want to open a case with TAC.
Cole
11-18-2010 02:02 PM
It ended up being a problem with the dn's.
The incorrect line was:
trunk A0
For it to work, it should be:
trunk A0 monitor-port 0/1/0
