LMS 3.2 : archive configuration with certificate
Jun 30th, 2010
Customer manage device config with LMS, when a device is down, he would like to push an archive config to a new device.
With device using certificate, he would like push the run config, but in LMS archive config he can't see config from sh run command.
He can see only, show run brief without certificate.
Before he had LMS 2.6, with 2 issues:
- out-of-sync run/startup conf for device using certificate.
- startup without certificate but with .cer file or running conf without certificate.
With LMS 3.2 with patch CSCta13429 he has running config or startup config without certificate.
Do you think he can push  running config or startup config without certificate to a new device ?
Many thanks,
Elisabeth
Sven Hruza Thu, 07/01/2010 - 02:13
we push the running-config of an damaged device to a new device without certificates and create the certificates by hand in the next step.
I thought that it is not possible to provide a running-config with certificate data in it to an accesspoint for example.
We got many failures doing this because the self-signed certificate is unique.
Is this right?
Sven
