Multiple MAC Addresses on Access Port
Jun 30th, 2010
We are trying to determine a way that we could easily view the mac table and only display the ports or macs that have multiple mac address attached to them.  We have a VOIP intiative that we are working on but we need to make sure there are no rogue hubs or switches attached at the access layer. Any guidance would be appreciated.
John Blakley Wed, 06/30/2010 - 09:10
  • Purple, 4500 points or more
I'm not sure if there's an easier way to do it, but here are a couple of options.
If you know what port you're concerned with, run:
sh mac address-table | inc
OR
sh mac address-table interface g3/0/27
HTH,
John
vladimirsaltao Wed, 06/30/2010 - 09:12
Best way, in my opinion, is to create a perl script from scratch.
Second best way is to use one that is already available like this one :
http://codewiki.wikispaces.com/cammer_c.pl
From the page:  "It will scan your network switches and provide information to help identify the devices attached to each port."
