Lost Central Manager configuration
Answered Question
Jun 30th, 2010
   Someone accidenltaly erased all the cm configuration. Is there any way to sync the configuration from edge-wae´s to the CM?
Correct Answer by Zach Seils about 6 years 7 months ago
Yes ... I believe most configurations are shown in the CLI these days.  Note that you'll have to run cms der force on each device before registering with the new CM.
Zach
Overall Rating: 5 (1 ratings)
Zach Seils Wed, 06/30/2010 - 13:26
Unfortunately not.  Do you have a backup of the configuration or a Standby Central Manager?
Zach
mario-leitao Wed, 06/30/2010 - 13:57
No, I just have the configurations applyed to the edge wae´s. I think the option I have is to check each edge wae configuration and replicate manually on the CM, right?
Correct Answer
Zach Seils Thu, 07/01/2010 - 04:30
Zach
