voice translation rules and voip dialpeers
Answered Question
Jun 30th, 2010
hello
i'd like to know if you could tell me what is matched first on a voip dial-peer
the destination-pattern or the translation rule. I'm a bit confused This is my scenario
voice translation-rule 2
rule 1 /\(^996\)\(.*\)/ /\2/
voice translation-profile Outgoing
translate called 2
dial-peer voice 9317 voip
translation-profile outgoing Voxitas
huntstop
destination-pattern 99611163171555
voice-class codec 2
session protocol sipv2
session target dns:65.33.11.223
no vad
When i make a test call i see 11163171555 however i don't if the translation rule was applied just before sending the digits to the next hop or if the destination pattern is matched first, then the translation and then the digits are stripped
could you please explain
Correct Answer by Brandon Buffin about 6 years 8 months ago
The destination pattern is matched first. This determines which dial peer will be used. The translation profile is then applied in this case stripping 996. The digits are then sent to the session target device.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 06/30/2010 - 12:55
Hope this helps.
Brandon
