Showing results forĀ
Search instead forĀ
Did you mean:Ā
huntstop on voip dial peers
hello i have an issue that you could be able to help me resolve
i have  a couple of voip dial peers for redundancy
this is what i want to accomplish, when the voice gateway isn't able to route the call by using the 1st dial-peer I want the router to stop hunting the next possible matches. so if i call 11163171555 and if  by some reason the gateway can send the call out by using dialpeer 9317. i don't want the gateway to try the next dial-peer.  with the config shown below this isn't happening.
what else do i need to do ?
this is my configuration
dial-peer voice 9317 voip
translation-profile outgoing Voxitas
huntstop
destination-pattern 99611163171555
voice-class codec 2
session protocol sipv2
session target dns:65.33.11.223
no vad
dial-peer voice 9318 voip
destination-pattern 996T
voice-class codec 2
session target dns:65.43.11.223
no vad
0 Replies 0
