what is the best solution for RA VPN backup on asa?
Jun 30th, 2010
hi All,
i'm trying to choose between landing ra-vpn on active\stanby asa5510 pair and vpn load-balance feature.
if i'll choose failover pair then i'll have a problem with dynamic routing.
if i'll choose load-balance feature then i should solve problem with assymetric routing for outgoing traffic from the clients in local net. or may be i;m wrong?
please advise me.
Michael Dombek Mon, 07/05/2010 - 07:58
Hi, both solutions would not cause problems
if i'll
If you're going Active / Passive you can have dynamic Routing - if you go Active / Active you can´t have VPN anyway so this is no solution
if i'll
Afaik (sorry it´s been a while with load balancing) the client stays connected to the ASA that it connects first (persistent) and you can automaticaly redistribute a /32 route into your routing Process.
If you don´t like this option you can create different pools on your VPN ASAs and do some statice routing.
Hope I did not mix up to many facts - HTH you
cheers Michael
