Inbound SIP Call Fails to CME from ISP
Jun 30th, 2010
Error is: ReqLine IP addr does not match with host IP addr Invalid URL in incoming invite The sip invite is received with an
and the router seems unable to make the translation from the public IP to the CME at private 192.168.1.x The error can only be seen in a debug ccsip (error or all i/e) and does not show in debug voip ccapi inout. After debugging with VoicePulse they cannot give me an answer. Outbound calls complete.
Abu Hadee Thu, 07/01/2010 - 02:13
Can you upload the sip debug? debug ccsip all will be good as I want to see the actual msg coming from provider
thank you
-abu
martibarber Sun, 05/15/2011 - 15:41
Was this issue ever resolved? I am experiencing the same problem at a Customer Site.
-marti-
Paolo Bevilacqua Mon, 05/16/2011 - 05:28
Do you have CME behind NAT? If yes, what type of device is doing NAT ?
Always include relevant traces when reporting problems.
martibarber Tue, 05/17/2011 - 03:17
Yes, uc500 behind nat. nat is running off a simple netgear box supplied by ISP. I have got it working by adding a loopback with the outside ip on the uc500 (an ip spoof) but it doesnt feel like the best thing to do. What really had me tearing my hair out is that an older configuration worked without the loopback...but I can't find a difference that would account for that.
-marti-
