Where can I find difference between IOS IP base and IP services for 3750E?
yinqingshan
I need encryption on switch 3750E. But the 3750E feature website only says IOS IP base or IP sesrvices. I can't search detailed information of IP base and IP sesrvices. Where can I find it?
Qingshan
4 Accepted Solutions
Leo Laohoo
IP Base is a Layer 2 only feature set.  You can't do any Layer 3 routing and you'll need the IP Services and up to do routing.
taali
QingShan -
IP Base provides you with Layer 2 features and basic Layer 3 functionality such as static routing, RIP and EIGRP stub.
IP Services provides you with Layer 2 features and full Layer 3 functionality, i.e OSPF, EIGRP, BGP, Policy-Based Routing, IPv6 in HW, etc.
Look at Question 2 in the link below for additional details.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/prod_qas0900aecd805bbea5.html
Ganesh Hariharan
Qingshan
Qingshan,
The IP base is for the Standard Multilayer Software Image (SMI) switches, and the IP services image is for the Enhanced Standard Multilayer Software Image (EMI) switches in Cisco IOS  Software Release 12.2(25)SEB and later.
The IP Base feature set includes advanced quality of service (QoS), rate limiting, access control lists (ACLs), and basic static and Routing Information Protocol (RIP) functions. Dynamic IP routing protocols (Open Shortest Path First (OSPF), BGPv4, Enhanced Interior Gateway Routing Protocol (EIGRP)) are available only on the IP services image.
The IP Services image provides a richer set of enterprise-class features, which includes advanced hardware-based IP unicast and IP Multicast routing. Support for IPv6 Layer 3 switching in hardware is also available with the addition of the Advanced IP Services license to either the IP Base or the IP Services images. Both the IP base Image and the IP services image allow for Layer 3 and Layer 4 lookups for QoS and security.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
taali
Hi Qingshan
Encryption is not supported on the 3750E.
The 3750-X switch that was released not too long ago supports MacSec encryption on the downlink ports.
See:  http://www.cisco.com/en/US/products/ps10745/index.html
Leo Laohoo
taali
QingShan -
Ganesh Hariharan
Qingshan
Qingshan,
Hope to Help !!
Ganesh.H
taali
Hi Qingshan
