what is this meaning???
Jun 30th, 2010
Hi again to all,
just want to ask if anyone know what is the fcpa in cisco catalyst 3750?
it is a catalyst 3750- 12 SFP port. and i need to configure it with vlan and access list.
my problem is when i already configured it and test it connection it doesnt work.
but in my packet tracer when i try the same configuration it works.
I think my problem is the configuration on the fiber portl.
I dont know how to trunk the fiber port going to the switch.
here's my configuration
urrent configuration : 1568 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750g-12s
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface Vlan1
no ip address
interface Vlan2
ip address 172.17.3.162 255.255.0.0
ip access-group ACL_TO_SERVERS out
interface Vlan3
ip address 172.25.70.1 255.255.255.0
interface Vlan4
ip address 172.25.71.1 255.255.255.0
ip classless
ip http server
ip access-list extended ACL_TO_SERVERS
permit ip 172.25.70.0 0.0.0.255 172.25.71.0 0.0.0.255
permit ip 172.25.71.0 0.0.0.255 172.25.70.0 0.0.0.255
permit ip 172.25.70.0 0.0.0.255 host 172.17.3.120
permit ip 172.25.71.0 0.0.0.255 host 172.17.3.120
permit ip host 172.17.3.120 172.25.70.0 0.0.0.255
permit ip host 172.17.3.120 172.25.71.0 0.0.0.255
control-plane
line con 0
line vty 5 15
Interface GigabitEthernet1/0/1 is configured as trunk going to the other switch.
but i think it doesnt work.
can anyone help me how to make it work and what command should i do to trunk the fiber optic port?
please help me....
thank you so much......
nelba_aldovino Wed, 06/30/2010 - 18:24
The catalyst 3750 is connected on the SRW2016.
Vlan instance is on the SRW2016.
here's the configuration of the SRW2016
interface ethernet g16
exit
vlan database
vlan 2-4
exit
interface range ethernet g(2-5)
switchport access vlan 2
exit
interface range ethernet g(6-10)
switchport access vlan 3
exit
interface range ethernet g(11-15)
switchport access vlan 4
exit
interface vlan 2
name SUBNET16
exit
interface vlan 3
name SERVERS
exit
interface vlan 4
name IT
nelba_aldovino Wed, 06/30/2010 - 18:35
hi leolaohoo,
this is what my design
in packet tracer it works but when it comes to real switches it doesnt work.
i did same configuration as what i did on the packet tracer.
taali Wed, 06/30/2010 - 18:55
Nelba
Can you paste the output of 'show vlan brief' and 'show interfaces trunk' from both switches.
nelba_aldovino Wed, 06/30/2010 - 21:44
hi taali,
here'e the utput for Catalyst 3750
Switch#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/2, Gi1/0/3, Gi1/0/4
                                                Gi1/0/5, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11, Gi1/0/12
2    SUBNET16                         active
3    SERVERS                          active
4    IT                               active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Switch#show interfaces trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi1/0/1     on           802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/1     1-4094
Port        Vlans allowed and active in management domain
Gi1/0/1     1-4
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     1-4
here's the output for SRW2016
console# show vlan
Vlan       Name                   Ports                Type     Authorization
1           1               g(1,16),ch(1-8)          other       Required
2       SUBNET16               g(2-5,16)           permanent     Required
3        SERVERS              g(6-10,16)           permanent     Required
4          IT                  g(11-16)            permanent     Required
There is no show int trunk command in linksys cisco SRW2016
that's why i'll just show the startup-config output of it which is equivalent to show running-config in cisco cli.
console# show startup-config
exit
vlan database
vlan 2-4
exit
exit
switchport trunk allowed vlan add 2
exit
exit
switchport trunk allowed vlan add 3
exit
exit
switchport trunk allowed vlan add 4
exit
interface vlan 2
name SUBNET16
exit
interface vlan 3
name SERVERS
exit
interface vlan 4
name IT
nelba_aldovino Thu, 07/01/2010 - 00:49
I can now ping the ip on the cisco 3750.
I have now another problem with my access list.
My accesslist was configured on cisco 3750 but it was not detected when connected to the SRW2016.
I dont know what's the problem..
here's the scenario:
i did the figure above on the real switch i connect a pc on SRW2016
here's the ACL configuration of cisco 3750
          Extended IP access list ACL_TO_SERVERS
              10 permit ip 172.25.70.0 0.0.0.255 172.25.71.0 0.0.0.255
              20 permit ip 172.25.71.0 0.0.0.255 172.25.70.0 0.0.0.255
In packet tracer it works but on the real switch I can't ping the DC server from the pc or vise versa.
But i can ping the gateway on the cisco 3750 of the DC Server and pc.
I dont know if the problem is on the cisco or on the SRW2016.
but i think configuration on cisco is correct i just don't know how will i connect the ACL from the cisco to SRW2016.
In packet tracer by using trunk it will allow all the configuration of the cisco to the switch.
But i already trunk the cisco to switch as shown on the figure but unfortunately it doesnt work
please help.....
