rsa key pix 8
Jun 30th, 2010
After I reload the PIX 515 with version 8.0(4)31
I checked the rsa key, it's not there.
I generated my key "crypto key generate rsa modulus 1024" again
save it using "write mem" and then reload,
it disappear after reload. Is it the right behavior?
Thanks for any reply.
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Mon, 07/05/2010 - 09:12
  • Green, 3000 points or more
The  crypto config key is not seen if you issue show run  or show start if that is what you meant in your post, the key should still be there ,  the show crypto key command syntax  bellow should provide details of your configured crypto key and modulus size etc.., or is it your case that no output is seen when you issue  the command bellow?
#show crypto key mypubkey rsa
