CISCO 1861 Switch port port security
Jun 30th, 2010
Hi all,
i have installed Cisco 1861 Router with 8 PoE switching ports , as per the company security policy we should enable the port security as following
interface GigabitEthernet0/2
switchport port-security maximum 3
switchport port-security violation protect
switchport port-security aging type inactivity
but its not accepting this command more over i dont want to hardcode the MAC address to the interfaces since i want the switch to handle it automatically because users are roaming frequently.
please assest with the same:)
Leo Laohoo Wed, 06/30/2010 - 22:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Get wireless.
Why "3"?  Why not just set to 1?
Muzzamil Hussain Wed, 06/30/2010 - 23:18
until now we dont have a wireless infrastructure
why 3 because we for every user will be 1 PC or labtop , 1 IP phone, last MAC is kept as free.
Leo Laohoo Thu, 07/01/2010 - 04:29
  • Hall of Fame,
    2017 LAN, Wireless
Use the following commands:
switchport access vlan
1 IP phone
switchport access voice vlan
Never heard of this before.
amvarana Wed, 06/30/2010 - 23:03
  • Cisco Employee,
What is the switching module you are using on the router ?
What is the IOS version you are running
Could you attach a snapshot of the error message you are recieving while configuring those commands
Muzzamil Hussain Thu, 07/01/2010 - 02:20
R1# show Diag
C1861 Mainboard 1FE, 8FE POE, Stacking FE, MOH, Port adapter
        Port adapter is analyzed
        Port adapter insertion time unknown
R1# show version
Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Cisco C1861-SRST-F/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K bytes of memory.
Processor board ID FHK141070QC
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
12 User Licenses
10 FastEthernet interfaces
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
128K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
amvarana Thu, 07/01/2010 - 21:50
  • Cisco Employee,
Hi Muzzamil
ISR 1861 does not support port security features.
You may try mac-address-table secure feature.
However you would have to hard code mac addresses for a particular interface
Refer this document for more on that
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_m1.html#wp1085966
Also when you secure a mac on a router with "mac-address-table secure" command it will set the port into secure mode
It will only allow the mac address you have listed access to the network.
The ports will not  be shutdown or err-disabled for any violations.
Related Content
