MCS7845 and MCS7835 within the same cluster
Jul 1st, 2010
We have 2 clusters CUCM 5.1.3. The main one is built with 3xMCS7845, the second one is built with 3xMCS7835.
We want to consolidate them to one cluster. I would like to reuse the MCS7835 platform server and add them to the main Cluster.
Is it possible to have a cluster with MCS7845 and MCS7835 platfrom?
Many Thanks
JP
Hardware Resources Hardware platform type 7845H
The CPU type Intel(R) Xeon(TM) CPU 3.40GHz
Memory 4096 Mbytes
Detailed Report Machine_Type = XXXX
Model_Number =
Serial_Number = USE619N321
Product_Name = ProLiant DL380 G4
BIOS_Version =
BIOS_Build_Level = P51
BIOS_Date = 04/26/2006
BIOS_Manufacturer = HP
BIOS_Language =
Number_Of_Enclosures =
Enclosure_Type.0 =
Processor_Slots = 2
Active_Processors = 2
Processor_Family.0 = Xeon
Processor_Speed_MHz.0 = 3400
Total_Enabled_Memory_Mb = 4096
ROM_Diagnostics_Build_Level =
Hardware Resources Hardware platform type 7835H
Memory 2048 Mbytes
Model_Number =
Serial_Number = USE632N6PQ
BIOS_Version =
BIOS_Language =
Enclosure_Type.0 =
Processor_Slots = 2
Active_Processors = 1
Total_Enabled_Memory_Mb = 2048
Jaime Valencia Thu, 07/01/2010 - 06:40
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, but you need to plan accordingly for failover configs, choice of PUB and TFTP
Review this config for recommendations on servers.
Publisher
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/5x/50clproc_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1049306
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
