CSM - Device update capabilities
Jul 1st, 2010
Most of my question is already answered but I have to be sure about the capability of the CSM (and the Auto Update Server) about the update of my "Security Devices" (ASA 5500, AIP-SSM, IPS 4200).
(I am talking about the CSM 3.3.1 and 4.0)
With the CSM can I remotely on a large infrastructure update:
- the ASA software : I think yes. What about 2 ASA in active/passive mode?
- the AIP-SSM software?
- the AIP-SSM recovery partition?
- the IPS 4200 software?
- the IPS 4200 recovery partition?
- the IPS signature update file: yes
If one this updates cannot be done by the CSM, it means that I have to do it device by device?
If my CSM server is offline, can I manually download the IPS sig updates and put them on the CSM?
During the software update on these devices, is the configuration saved ?
Thanks in advance!
jacques_henry696 Thu, 07/08/2010 - 00:10
Thanks for the answer!
Ok, but can AUS also take care of the IPS 4260 and AIP-SSM?
Is RME fully integrated into the CSM or is it an external application?
Scott Fringer Thu, 07/08/2010 - 07:22
CSM will directly handle auto-updating of IPS sensors; AUS is not used.  You simply need to configure the IPS updates in the Security Adminsiration; within the CSM client:
Tools>Security Manager Adminsitration...
Choose "IPS Updates"
Configure the Auto Update Settings in the left-hand pane as required for your environment.
RME is no longer a required component of CSM and is a separate application.
Scott
jacques_henry696 Thu, 07/08/2010 - 09:13
All right, so to sum up, I can do all the tasks in my first post (the 6 points) with the CSM (without RME), yes?
Thanks!
Scott Fringer Thu, 07/08/2010 - 10:02
Yes, you should be able to accommodate ASA and IPS software management without the need to install RME; AUS for ASA image management and CSM for IPS software management.
Scott
