Answered Question
Jul 1st, 2010
I cannot access my FWSM after module reset.
Ive already try a to issue this command     ( Core#hw-module switch 1 module 1 reset mem-test-full ) but still unable to access and ive already try to re-slot in the module but still doesnt work and also try to re-slot in available slot but still no luck. is there any solution that i need to do , My core switch is now on production . thanks for the help. You can see the error message below...
Core#session switch 1 slot 1 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying ...
% Connection timed out; remote host not responding
Correct Answer by Marcin Latosiewicz about 6 years 3 months ago
Are you sure your failover vlans are added to the blade with?
There's a bug for this - not being able to access the blade if failover vlans is not added.Perhaps this is the case?
Overall Rating: 5 (1 ratings)
Jennifer Halim Sat, 07/03/2010 - 04:31
What is your core switch and FWSM version? Can you please share the output of "show version" and "show module".
wacha8888 Sat, 07/03/2010 - 13:06
Cisco 6509e
Core#sh module sw
Switch Number:     1   Role:   Virtual Switch Active
Mod Ports Card Type                              Model              Serial No.
  1    6  Firewall Module                        WS-SVC-FWM-1       SAD130600EB
  2   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL1313M8R0
  4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1312LYRR
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1312M626
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1312M2M9
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1322R1EL
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1322QYD3
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0021.a082.8c38 to 0021.a082.8c3f   4.5   7.2(1)       4.0(4)       Ok
  2  0024.c481.2274 to 0024.c481.22a3   1.13  12.2(14r)S5  12.2(33)SXI  Ok
  4  0021.a0ef.89f8 to 0021.a0ef.89ff   1.6   12.2(18r)S1  12.2(33)SXI  Ok
  5  001f.6cbd.42b8 to 001f.6cbd.42bf   3.1   8.5(3)       12.2(33)SXI  Ok
  7  0023.0456.d4f8 to 0023.0456.d527   3.0   12.2(18r)S1  12.2(33)SXI  Ok
  8  0025.8448.c240 to 0025.8448.c26f   3.0   12.2(18r)S1  12.2(33)SXI  Ok
  9  0025.8448.b6a0 to 0025.8448.b6cf   3.0   12.2(18r)S1  12.2(33)SXI  Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1311LPHN  4.1    Ok
  4  Distributed Forwarding Card WS-F6700-DFC3C     SAL1313M8LA  1.2    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1312LTYQ  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1309L1W7  1.1    Ok
  7  Centralized Forwarding Card WS-F6700-CFC       SAL1312M691  4.1    Ok
  8  Centralized Forwarding Card WS-F6700-CFC       SAL1322R02V  4.1    Ok
  9  Centralized Forwarding Card WS-F6700-CFC       SAL1321QQRT  4.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  4  Pass
  5  Pass
  7  Pass
  8  Pass
  9  Pass
Core#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-VM), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 07-Nov-08 05:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
VSSCore uptime is 44 weeks, 5 days, 20 hours, 28 minutes
Uptime for this control processor is 44 weeks, 5 days, 20 hours, 27 minutes
Time since VSSCore switched to active is 44 weeks, 5 days, 20 hours, 27 minutes
System returned to ROM by  power cycle at 04:54:00 UTC Tue Jun 2 2009 (SP by power-on)
System restarted at 07:36:22 UTC Mon Aug 24 2009
System image file is "sup-bootdisk:/s72033-adventerprisek9_wan-vz.122-33.SXI.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.4) with 1040384K/8192K bytes of memory.
Processor board ID SMC1310009C
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4294967288 Ethernet interfaces
96 Virtual Ethernet interfaces
408 Gigabit Ethernet interfaces
20 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Correct Answer
Marcin Latosiewicz Sat, 07/03/2010 - 14:33
wacha8888 Sun, 07/04/2010 - 05:37
Your right the failover vlan is not added . Affter adding the vlans its working now thanks.
