LMS Mini Dashboard unable to fetch from LMS
Jul 1st, 2010
The LMS Mini Dashboard was initially working fine.
Then when I integrated LMS with Cisco ACS, I am able to successfully login into the LMS Mini Dashboard using my ACS user account. But the LMS Mini Dashboard is unable to fetch data from LMS. Following are the errors
Unable to fetch Device Manageability Status from LMS server. User not authorised to view summary
Unable to fetch IP SLA Violations from the LMS server. Check to see if IFM is installed on the server.
Unable to fetch Configuration Status (RME[1] empty) from the LMS server.Error while getting Config Summary
Unable to fetch Inventory Status and Changes (RME[0] empty) from the LMS server.User not authorised to view summary
Thanks in advance
