Lookin for a NMS such as CiscoWorks network management software
eclipse81
hi everybody
I 'm lookin' for CiscoWorks network management software or equivalent on support section on cisco website support.
I want it to configure snmp on my catalyst 2950 and get some results likes input and output traffic rate on my catalyst, all trafic generated by equipment connected on my catalyst with some detailes likes equipement ip, input and output trafic rate, graph and son on.
I don't find it on the cisco website so I think they'll have an equivalent on the website but I don't know.
If someone has an idea or a link...
Thank you
ccarring
Hi Serge,
Are looking to obtain software that you can install and use, or are you looking for documentation for software you already have?
One type of network management software freely available is MRTG, it will produce graphs of network traffic, a very handy utility:
http://www.mrtg.com/
Another freeware NMS, if I'm not mistaken, is Nagios:
http://www.nagios.org/products/nagiospowered/
We do have some software available for device configuration also (depending on the device). Perhaps the Cisco Netowrk Assistant? You can navigate there from http://www.cisco.com . Choose Support, and under Otion 2, choose "Download Software". Then select "Netowrk Management", "Routing and Switching Management", and "Cisco Network Assistant". Follow the navigation, and you should be able to have a tool to help configure your devices.
Cheers,
Curtis
