ATM/E1 connection between 7200 E1-IMA and 2651 VWIC-1MFT-E1
Jul 1st, 2010
I have a 7200 with an E1-IMA card.
I have a 2651 with a VWIC-1MFT-E1.
I have them connected via an E1 cross-over (the cable has been tested between 2x7200 E1-IMA cards)
I can't get them to talk to each other.
Both ends show the PVC as: Status: up   and have green LED link lights
But one end shows the IP interface as up, the other end down
Can anyone help?
Configs:
7200 with E1-IMA
2651 with VWIC-1MFt-E1
hostname 7200-E1-IMA
ip cef
interface ATM1/0
no ip address
clock source internal
framing crc4adm
no ima-group
no atm ilmi-keepalive
interface ATM1/0.1 point-to-point
ip address 10.10.10.1 255.255.255.248
pvc 0/44
  ubr 1920
  encapsulation aal5snap
hostname 2651-VWIC-1MFT-E1
ip cef
controller E1 0/0
  mode atm
interface ATM0/0
  no ip address
interface ATM0/0.1 point-to-point
  ip address 10.10.10.2 255.255.255.248
  pvc 0/44
   ubr 1920
7200-E1-IMA#show atm pvc
           VCD /                                        Peak  Avg/Min Burst
Interface  Name         VPI   VCI  Type   Encaps   SC   Kbps   Kbps   Cells  Sts
1/0.1      1              0    44  PVC    SNAP     UBR    1920
UP
2651-VWIC-1MFT-E1#show atm pvc
0/0.1      1            0    44   PVC    SNAP     UBR    1920
UP
7200-E1-IMA#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
ATM1/0                     unassigned      YES NVRAM  up                    up
ATM1/0.1                   10.10.10.1      YES manual up                    up
2651-VWIC-1MFT-E1#sh ip int br
FastEthernet0/0            10.10.100.2     YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
ATM0/0                     unassigned      YES manual down                  down
ATM0/0.1                   10.10.10.2      YES manual down                  down
7200-E1-IMA#sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.3(1a), RELEASE SOFTWARE  (fc1)
System image file is "slot0:c7200-is-mz.123-1a.bin"
2651-VWIC-1MFT-E1#sh ver
IOS (tm) C2600 Software (C2600-JS-M), Version 12.2(2)XT, EARLY  DEPLOYMENT RELEASE SOFTWARE (fc1)
System image file is  "flash:c2600-js-mz.122-2.XT.bin"
Giuseppe Larosa Sat, 07/03/2010 - 10:47
Hello Chris,
in back to back setup one side provide clock using clock source internal and the other side should use clock source line.
you have set both routers for clock source internal change on C2651 to clock source line
Hope to help
Giuseppe
Related Content
