Fail to Wire in Cisco Pix 525 (on Transparent Firewall mode)??
Jul 1st, 2010
Is possible configure fail to wire in a PIX working on Transparent firewall mode, to allow pass all the traffic in case of shutdown o reset the PIX?
Best regards.
juancarlosmarti... Fri, 07/02/2010 - 00:32
I want say, with a single PIX, if I turn it off or restart it, if PIX allows traffic to pass through it like a cable
Jennifer Halim Fri, 07/02/2010 - 01:36
OK, thanks for the clarification.
The answer is no, if you reset the PIX firewall or turn it off, it will not pass any traffic at all.
Related Content
