how to print guest WLAN account password?
Answered Question
Jul 1st, 2010
When a guest wlan user is created (by the LobbyAdmn function) there I get back a pop-up box with her autogenerated password. This is normally a rather complex password. Is there any way to print this with e.g. a label printer so that I can give it to people and wish them good luck rather than writing it down, making errors, joking about my hand writing etc. etc.. I think that looks rather unprofessional.
Correct Answer by rob.huffman about 6 years 6 months ago
Hi Joerg,
This capability (sadly) is only available when creating Guest accounts
using the WCS,as shown in the attached doc. With WCS you have the
option to Print or email this info;
http://cisco.biz/en/US/docs/wireless/technology/guest_access/technical/reference/4.1/GAccess_41.html
Cheers!
Rob
Overall Rating: 5 (1 ratings)
with_joerg Fri, 07/02/2010 - 01:55
Hi Rob,
thanks for the advice that almost solved my problem. We have a WCS but use it for monitoring only. How does the WiSM learn from the WCS that a new visitor account has been created? Does the LobbyAdmin need to apply a config or so?
Thx,
--Joerg
