Giuseppe Larosa Thu, 07/01/2010 - 14:02
Hello Bill,
you should put offline the FWSM by removing all occurrences of firewall keyword
once the FWSM is not connected to outside world you can use hw-module module X command with appropriate option or better you can session to the module to prepare it to shutdown (to be preferred)
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/switch_f.html#wp1192467
once you have done these stes you should be able to remove it.
Also the NAM is a linux based appliance so the question is wise
in the case of NAM you should verify if there are any monitor sessions with destination= NAM
Hope to help
Giuseppe
Ganesh Hariharan Thu, 07/01/2010 - 22:53
Is there a procedure for powering off and remove the modules in a 6500? I am going to remove two FWSM and a NAM.
The firewall module should be removed only after you disable power using one of these methods. (There is no preference for a particular method.)
    * Use the command-line interface (CLI) of the switch and issue one of these commands.
          o  CatOS - set module power down mod
          o  Cisco IOS® Software - no power enable module slot
    * Press the shutdown button on the blade.
    * Physically power down the chassis.
You can remove the module safely when the status light is not green.
http://www.ciscosystemsnetwork.net/en/US/products/hw/modules/ps2706/products_qanda_item09186a00801e9e26.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
