Query on optimization issue.
Jul 1st, 2010
Consider the senario, We have two WAE registered to a CM.
The optimization of the entire system is not good. Need to check which WAE is not optimizing good?
Zach Seils Thu, 07/01/2010 - 08:25
  • Cisco Employee,
By "not good" do you mean that the connections aren't being optimized?  Or is it that the end user performance is worse?
Zach
tayyappa Thu, 07/01/2010 - 23:02
The connections aren't being optimized in my case.
Zach Seils Tue, 07/06/2010 - 05:12
  • Cisco Employee,
If you issue the command sh stat conn, what is the ConnType for the pass-through connections?
Zach
