ospf routing issue at different ospf process.
Jul 1st, 2010
I would like to know How I can do it for ping between pc1 and pc2.
first solution is to redistribute between two different process at boundary router.
but I wound't do it. except redistribute., Is there another way?
basically, if the ospf process is different, the routing can be changed only same ospf process. Right?
if so, I think that there is no way except redistribute at boundary router.
but I must run ping between pc1 and pc2.
thank you.
Chetan Kumar Ress Thu, 07/01/2010 - 07:44
  • Silver, 250 points or more
As per you requriment you don't want to redistribute between BR.
So as per you senario BR should have both route for OSPF process 1 & 2 ( R5 & R6)
As per my understanding if you originate an default route in both ospf process then it can work without redistribution.
Use  'default-information originated'  under ospf process in R5 & R6 for both process.
So if You will ping from PC1 the it will use default route to reach upto BR the from there if will take specific router to reach PC2.
same for reverse traffic.
Chetan Kumar
