Unity Connection 1.2 (Distorted system System Prompts & Messages
Jul 1st, 2010
Hi All,
I have a customer with Unity connection ver 1.2 on Windows 2003. The Staff  occasionally receive distorted system prompts and messages.
The Server is healthy no errors in events manager, CPU usage is < 10% when I checked and there is ample storage.
There isn't anything remotely close in Cisco Bug tool kit, therefore I'm wondering if there is probably a period when the CPU is Max out ???
Any advice appreciated.
Charles
Tray Stoutmeyer Thu, 07/01/2010 - 12:04
That is always a possibility but without seeing the cpu pegged at the time of the problem report or having some sort of perf mon running to catch that, it would be assuming alot. You could also make sure that the NIC cards have the latest drivers updated and also make sure you have both the NIC card set to 100/full and the switch port it plugs into set to the same 100/full. If they are Gig/full, make sure they match as well. Also, if the NIC cards are teamed, we only support NFT configuration so check that.
Tray
