cisco 3640 with 2 ISP & route-map load balancing
precisionlab
I'm trying to setup 3640 router with 2 ISP's. I can't have BGP because one ISP is comcast running on simple SMC modem/router/firewall but is it perfectly fine to have "route-map " type balancing. I'd like to have 5 IP addresses to use T1 and the rest comcast. (in my config only 1 is set -192.168.30.151)
What am I missing in my current config:
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname cisco3640
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$rpH4$/jrOUBf232342342b.
enable password 123xxxxxxxxx321
no aaa new-model
memory-size iomem 10
ip cef
ip name-server 4.2.2.2
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.30.1 192.168.30.150
ip dhcp pool 1
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
   dns-server 4.2.2.2 4.2.2.5
   domain-name mylocaldomain.com
   lease 1 1
interface FastEthernet0/0
description connected to localLAN
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
half-duplex
interface Ethernet1/0
description T1 internet
ip address 69.x.x.98 255.255.255.240
ip nat outside
full-duplex
interface TokenRing1/0
no ip address
shutdown
ring-speed 16
interface Ethernet2/0
description COMCAST internet
ip address 192.168.26.1 255.255.255.0
ip nat outside
half-duplex
router rip
version 2
passive-interface Ethernet2/0
no auto-summary
ip http server
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.26.254
ip route 0.0.0.0 0.0.0.0 69.x.x.97
ip nat inside source route-map ISP-T1 interface Ethernet1/0 overload
ip nat inside source route-map ISP-comcast interface Ethernet2/0 overload
access-list 10 permit 192.168.30.0 0.0.0.255
access-list 11 permit 192.168.30.151
route-map ISP-comcast permit 10
match ip address 10
match interface Ethernet2/0
route-map ISP-T1 permit 11
match ip address 11
match interface Ethernet1/0
control-plane
line con 0
line aux 0
line vty 0 4
password 123xxxxxxx321
login
end
mmacdonald70
I'm no expert in this but it looks like your route map statements have one too many match statements.  You are saying "Add the packet route route-map ISP-comcast if it matches access list 10 AND is comes in E2/0".  Try removing the second match statement.
shivlu jain
Level 5
Level 5
In the given acl
access-list 10 permit 192.168.30.0 0.0.0.255 the ip .151 is also permitted. Could you add deny first for .151 in acl 10 then permit 192.168.30.0 0.0.0.255
regards
Shivlu Jain
http://www.mplsvpn.info
