07-01-2010 12:05 PM - edited 03-15-2019 11:30 PM
Very quick question:
At what point in a upgrade of Call Manager do you require a license upgrade as well?
If I'm going between say 7.1(3) to 7.1(5) or if I say go from 7.1(x) to 7.2(x).
Or is it simply between major versions say 7.x to 8.x
Thanks in advance,
Neil
07-01-2010 12:16 PM
My understanding is this:
Upgrades to a new "train" of code requires a new Software Feature License. So for example;
CUCM 6.0(x) to 6.1(x) = No
CUCM 6.(x) to 7.0(x) = Yes
In these cases, if you are current on UCCS then you can order the appropriate upgrade via the Product Upgrade Tool (PUT).
Hailey
Pls rate helpful posts!
07-01-2010 12:19 PM
v. helpful - thanks for the quick reply.
