WPA Migration Mode
Answered Question
Jul 1st, 2010
We have Cisco Aironet 1130AGs. We are going to transition our network to WPA, but now it's all WEP. I'd like to set up WPA Migration mode on all of our access points so WEP and WPA clients can access it, but I'm having problems setting it up. Does anyone have a step-by-step guide for this?
Scott
Correct Answer by andre.ortega about 6 years 9 months ago
Hi Scott,
follow commands for this configuration:
ap1200# configure terminal
ap1200(config)# configure interface dot11radio 0
ap1200(config-if)# ssid migrate
ap1200(config-ssid)# authentication open
ap1200(config-ssid)# authentication network-eap adam
ap1200(config-ssid)# authentication key-management wpa optional
ap1200(config-ssid)# wpa-psk ascii batmobile65
ap1200(config-ssid)# end
ap1200(config-if)# encryption mode cipher tkip wep128
ap1200(config-if)# encryption key 3 size 128 12345678901234567890123456 transmit-key
Overall Rating: 5 (2 ratings)
Correct Answer
andre.ortega Fri, 07/02/2010 - 05:21
  • Bronze, 100 points or more
  • Participante em Destaque,
    Escolha da Audiência, Maio de 2015
Hi Scott,
Scott Pazelt Tue, 07/06/2010 - 13:11
Thanks Andre.
The command - ap1200(config-if)# ssid migrate
Is "migrate" the name of the ssid?
Is there a way to do this through the web interface?
Scott
andre.ortega Tue, 07/06/2010 - 14:04
Yes, migrate is SSID name.
I belive configure in web interface is possible, but I never try and have not Cisco guide.
But you can try this in web interface
SSID Manager
     Select SSID > Your SSID
     Open Authentication > NO ADDITION
     Key Management > Optional
     WPA PSK > Youer WPA PSK
     Apply
Encryptation Manager
     Set Encryption Mode and Keys for VLAN > Your VLAN
      Cypher > TKIP + WEP40 or WEP128
     Encryptation Keys
          Encryptation Key 3 > Your WEP Key
Can be necessary change some option...
Trending Topics - Security & Network
