07-01-2010 08:18 PM - edited 03-15-2019 11:31 PM
Hello All,
I'm trying to set up a translation rule and I'm getting invalid string as return, for me the command is correct. I saw the exactly command on a different router.
Any help appreciated
RIO1RT009448(config-translate)#rule 1 /^.*/ /9&/ subscriber subscriber
Incorrect format for Translation Match Pattern
regular expression must be of the form ^(\^)?(\+)?([0-9,A-F.*%?#]+)$
Invalid match pattern string input /^.*/
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
There were any changes on the command syntax?
Solved! Go to Solution.
07-02-2010 05:56 AM
Rafael,
No, not a defect. I just noticed the prompt in your samples. You are using
a "translation-rule" as opposed to a "voice translation-rule". I just
confirmed on my lab router that I have the same syntax error message when
applying the configure to a "translation-rule".
Can you try:
Voice translation-rule 10
rule 1 /.*/ /9&/ type subscriber subscriber
Voice translation-profile testprofile
translate called 10
The translation-rule tag (10 in the example) is arbitrary as is the profile
name (testprofile). Use whatever makes sense in your environment. The
distinction of called vs. calling is to define which information element you
want to tweak. You can assign the translation profile as ingress or egress
on whatever dial-peer makes sense.
HTH.
Bill
On 7/2/10 8:10 AM, "rafaelchavantes"
07-01-2010 08:39 PM
Rafael,
I tested this out on my lab system. On 12.4(24)T2 I can use the following
syntax:
voice translation-rule 5055
rule 1 /^.*/ /9&/ type subscriber subscriber
Test:
iecube01#test voice translation-rule 5055 5551212 type subscriber
Matched
with rule 1
Original number: 5551212 Translated number:
95551212
Original number type: subscriber Translated number type:
subscriber
Original number plan: none Translated number plan: none
So, first on the 12.4(24)T train I can use the carrot symbol. Which appears
to not work in your version. Second, I had to specify the keyword type.
I also tested this config:
And it worked fine. There is no need to use the carrot to designate the
start of a string when you are actually consuming the entire string anyway.
Just a thought.
HTH.
Bill
Please remember to rate helpful posts.
On 7/1/10 11:18 PM, "rafaelchavantes"
07-02-2010 05:10 AM
Bill,
In my version of IOS it does not ask for the type command as follows:
RIO1RT009448(config-translate)#rule 1 /.*/ /9&/ ?
abbreviated The numbering type is abbreviated
any Any numbering type
international The numbering type is international
national The numbering type is national
network The numbering type is network
reserved The numbering type is reserved
subscriber The numbering type is subscriber
unknown The numbering type is unknown
RIO1RT009448(config-translate)#rule 1 /.*/ /9&/ subs
RIO1RT009448(config-translate)#rule 1 /.*/ /9&/ subscriber subs
RIO1RT009448(config-translate)#rule 1 /.*/ /9&/ subscriber subscriber
regular expression must be of the form ^(\^)?(\+)?(+)$
Invalid match pattern string input /.*/
But continue to say that is an invalid string, do you think that could be a IOS bug?
07-02-2010 05:56 AM
Rafael,
Can you try:
translate called 10
HTH.
Bill
07-02-2010 06:32 AM
Thanks Bill.
I couldn't believe I've didn't notice that before.
Just another question I've just made here a sample test but did not work.
In case of changing the calling number to make the user able to redial the call, in what dial-peer I should put this?
07-02-2010 06:55 AM
Rafael,
I assume you mean ingress from PSTN and presented to IP phones? Well, there are multiple ways I am sure, but sticking with the theme of the thread:
If we assume I live in 703 area code:
voice translation-rule 10
rule 1 /^703/ /9703/
rule 2 /^202/ /9202/
rule 3 /^571/ /9571/
rule 4 /.*/ /91&/
voice translation-profile testprofile
translate calling 10
Just a rough example. From 703, there are several areas that are local to me. Like 202 and portions of 571. Anything outside of those areas I will stick a 91 (i.e. long distance). This is all for the NANP and is a simplistic example. I am not sure what would make sense for your operating area.
HTH.
Bill
Please remember to rate helpful posts!
07-02-2010 09:29 AM
Bill,
I've made a translation here according to my operator and the test works, but the question is where to apply it.
I've made a test doing a inbound call and checked which dial-peer matched and applied the translation-profile to that dial-peer.
Now I have two questions:
a) The TON (Type of number) is applied to E1 R2? ==> this is being discussed on the this topic => https://supportforums.cisco.com/message/3130696#3130696
b) I'm doing this on the wrong dial-peer?
