Cisco works LMS 2.6 login error
Jul 1st, 2010
I am running Cisco works LMS 2.6 in our organization. After run the Airconics backup on the system (Windows 2003) I am seeing the blank page after I login to Cisco works.
I attached the error which displayedand also display the error log. can you please any one advise what could be the problem and how to rectify this issue.
I can use " net stop/start crmdmgtd" but sometimes it takes 20 minutes to stop. Sometimes its very first to stop the service.
After stop/start I tried to use "pdterm ANIServer" but system reply
ERROR: GetReply from server failed:
ERROR: Daemon Manager startup in progress. Please wait.
I tried many times but still the same error.
Here is the log from ciscoworks.
Jun 30 16:16:42 127.0.0.1 100: <30>   dmgt[1992]: 3007(I):Started application(EssMonitor) "C:\PROGRA~1\CSCOpx\bin\cwjava.exe -cp:a C:\PROGRA~1\CSCOpx com.cisco.nm.cmf.ess.EssMonitor" pid=4540.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2005(W):Internal Error: The maximum number of retry attempts (3) to restart application (TomcatMonitor) has been reached.  This application will not be restarted. Call your technical support representative for assistance.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2005(W):Internal Error: The maximum number of retry attempts (3) to restart application (EDS) has been reached.  This application will not be restarted. Call your technical support representative for assistance.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2005(W):Internal Error: The maximum number of retry attempts (3) to restart application (EssMonitor) has been reached.  This application will not be restarted. Call your technical support representative for assistance.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2039(W):An application (LicenseServer) has terminated. No action necessary.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2119(W):A registered application, LicenseServer, exited with an unexpected status, stopped with signal 1073741823, exit value -1  and no  core dump.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2053(W):An application that is not registered sent a status message ServNotificationDM to the daemon manager.  The message was ignored.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2055(W):An application that is not registered sent message ServNotificationDM to the daemon manager.  The message was ignored.
Jun 30 16:17:43 127.0.0.1 100: <30>   dmgt[1992]: 3007(I):Started application(LicenseServer) "C:\PROGRA~1\CSCOpx\bin\cwjava.exe -DNMSROOT=C:\PROGRA~1\CSCOpx  -cp:p lib\classpath;objects\log4j\1.1.3\log4j.jar;lib\classpath\License.jar -cw:jre MDC\jre com.cisco.nm.license.server.LicenseServer" pid=6156.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2053(W):An application that is not registered sent a status message Archive Mgmt to the daemon manager.  The message was ignored.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2055(W):An application that is not registered sent message Archive Mgmt to the daemon manager.  The message was ignored.
-DNMSROOT=C:\PROGRA~1\CSCOpx  -cp:p lib\classpath;objects\log4j\1.1.3\log4j.jar;lib\classpath\License.jar -cw:jre MDC\jre com.cisco.nm.license.server.LicenseServer" pid=6884.
Jun 30 16:17:43 127.0.0.1 100: <30>   dmgt[1992]: 3007(I):Started application(LicenseServer) "C:\PROGRA~1\CSCOpx\bin\cwjava.exe -DNMSROOT=C:\PROGRA~1\CSCOpx  -cp:p lib\classpath;objects\log4j\1.1.3\log4j.jar;lib\classpath\License.jar -cw:jre MDC\jre com.cisco.nm.license.server.LicenseServer" pid=4392.
Jun 30 16:17:43 127.0.0.1 100: <28>   dmgt[1992]: 2095(W):Internal Error: The daemon manager cannot run application Exceeded maximum restart attempts 3.
  Thanks In advance
S.Rajkumar
