Any limit on interface numbers for WCCP interception
Jul 1st, 2010
May I know if there is any limit on the number of router interfaces for WCCP interception?
For example, there is an end site with primary and backup MPLS circuit, together with 5 or 10 LAN interfaces (in VLANs):
interface fa0/1
ip wccp 62 redirect in
interface serial1/0
interface vlan 5
ip wccp 61 redirect in
interface vlan 6
interface vlan 7
Joe
Marcin Latosiewicz Fri, 07/02/2010 - 16:55
  • Cisco Employee,
Joe,
If limit extists it will be per-platform. What are you using?
I'm not familair with the numbers but can dig it up for you (hopefully)
Marcin
Joe Lau Fri, 07/02/2010 - 20:53
Hi Marcin,
We are using ISRs like 3845/3825/2821/2811...
Joe
Joe Lau Sun, 07/04/2010 - 19:44
Hi Marcin,
Thanks a lot for the info!
Joe
