Policy Based Routing On Cisco 3560 Switch
Jul 1st, 2010
I am having cisco 3560 switch and I have two ISPs. From that ISP A has two links on two different interfaces on cisco 3560 switch. Out of that one is primary link and second one is secondary. Also I have ISP B coming on the same switch. I have to configure Routing on 3560 switch such that traffic coming from certain source should go through ISP A primary link and if primary link fails it should go from ISP A secondary link. And the remaining traffic specific to ISP B should be routed through ISP B.
Richard Burts Thu, 07/01/2010 - 21:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Prasad
Since the 2960 is a layer 2 only switch (no capability at layer 3) I believe that you will not be able to configure Policy Based Routing on this switch.
Rick
PRASAD BAIT Thu, 07/01/2010 - 22:32
Hi Rick,
Sorry i gave you wrong information. I have 6224 switch and i need to do this on 6224 switch
Prasad
PRASAD BAIT Thu, 07/01/2010 - 22:50
Hi Rick,
Sorry I gave you the wrong information. I am having cisco 6224 switch.
Prasad
On Fri, Jul 2, 2010 at 10:08 AM, rburts
Richard Burts Thu, 07/01/2010 - 23:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Prasad
The Cisco 6224 is a blade for a switch chassis. Can you provide specific information about the switch chassis in which the 6224 will work?
Rick
Ganesh Hariharan Thu, 07/01/2010 - 22:53
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
I am having cisco 2960 switch and i have two ISP. From that ISP A have two links on two different interfaces on cisco 2960 switch out of that one is primary link and second one is secondary. Also I have ISP B coming on 2960 switch. I have to configure Policy based Routing on 2960 switch such that traffic coming from certain Vlans should go through ISP A primary link and if primary link is failed it should go from ISP A secondary link. Also traffic coming remaining Vlans should go from ISP B.
As suggested by Rick you cannot do PBR with 2960 switch as it a L2 switch and for PBR to be work you need the enhanced image for PBR with L3 functionality of the switch.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
PRASAD BAIT Fri, 07/02/2010 - 00:49
I have edited the thread with correct and specific information.
Ganesh Hariharan Fri, 07/02/2010 - 01:11
Hi Prasad,
Check out the below link for PBR configuration
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html
Hope to Help !!
Ganesh.H
Related Content
