07-02-2010 01:02 AM - edited 03-15-2019 11:31 PM
Hi to all
i see here many posts for this issue but i didnt find anywhere a clearly answer so i decided to open a new document
Here we have to PRIS
On controller 0/0/0 incoming and outgoing are fine
On controller 0/1/0 outgoing is ok but incoming has problem(not some calls but all the calls)
Note::
((((when you call to a number you hear a busy tone , but the called person see on his phone 2 missed calls))))
Below is the debug for a fail call
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839D
Exclusive, Channel 29
Calling Party Number i = 0x2181, '22551256'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '25002122'
Jul 1 08:36:21.635: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0x8E8D callID = 0x09A0 switch = primary-net5 interface = User
Jul 1 08:36:21.659: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8E8D
Jul 1 08:36:21.683: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8E8D
Jul 1 08:36:21.691: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0E8D
Cause i = 0x82D1 - Invalid call reference value
Jul 1 08:36:21.711: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0E8D
Jul 1 08:36:21.715: ISDN Se0/1/0:15 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x8E8D callid 0x0
I believe that the problem is not on our site but on ISP site
what is your opinion
router#sh ver
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.T2.bin"
07-06-2010 09:45 PM
What is your isdn switch type ?
07-06-2010 10:34 PM
hi
thanks for your reply
isdn switch-type primary-net5
07-06-2010 11:18 PM
Invalid Call reference value indicates that the far-end witch did not recognize the call reference for a message sent by the gateway. So yo need to make sure you are using the matching isdn switch type with your far end, or you can try different switch type to see if there is any one worked better
07-06-2010 11:23 PM
The strange is that with this ISP we have two PRIS
The first PRI on outgoing and incoming its ok
The second PRI has problem only to incoming calls
The ISP say that they have the same Config for both PRIS
Its possible to have a problem on our controller (on our GW) or its a fantastic theory
