Cisco ASA 5540 maximum memory
Answered Question
Jul 2nd, 2010
Does anyone know what is the maximum RAM that can be installed in cisco ASA 5540?
Thank you,
Correct Answer by Jennifer Halim about 6 years 6 months ago
The 4GB DRAM is only for ASA 5580 model. It is not available for the lower ASA series.
So to answer your questions:
1. Yes, 2 GB is the maximum for ASA5540
2. ASA5540-MEM-2GB=  comes with 2 DIMMS (1GB each).
Overall Rating: 5 (1 ratings)
Muhammad Khan Fri, 07/02/2010 - 01:44
Thank you Halijen.
Looking at the release notes it does say
"On both the ASA 5580-20 and the ASA 5580-40 adaptive security appliances only 4 GB of memory is available for features. The rest are reserved or used by the OS. The show memory command will only display values relative to 4 GB."
1. Does this still mean that 2GB is the maximum memory we can install?
2. Does 2GB (ASA5540-MEM-2GB=) come as a sing module or 4x512 MB modules?
Rgds,
Correct Answer
Jennifer Halim Fri, 07/02/2010 - 01:55
