07-02-2010 01:57 AM - edited 03-04-2019 08:57 AM
I am installing the below into a 7600 running the below IOS and it reports as "unknown" in the online diag status. The ports appear on the router, but will this work when a 2m circuit is connected??
4-subslot SPA Interface Processor-200 7600-SIP-200
8xCHT1/E1 SPA SPA-8XCHT1/E1
Specified card type in config:
"card type e1 2 0"
PPCW_R76_501#sh mod
Mod Ports Card Type Model Serial No.
2 0 4-subslot SPA Interface Processor-200 7600-SIP-200 JAE1342LIQX
Mod MAC addresses Hw Fw Sw Status
2 0027.0dba.cf40 to 0027.0dba.cf7f 2.303 12.2(33)SRB7 12.2(33)SRB7 Ok
Mod Sub-Module Model Serial Hw Status
2/0 8xCHT1/E1 SPA SPA-8XCHT1/E1 JAE141206IF 1.5 Ok
Mod Online Diag Status
1 Pass
2 Pass
2/0 Unknown <<<<<<<<<< should state PASS!!!
5 Pass
6 Pass
IOS :bootdisk:/c7600s3223-ipservicesk9-mz.122-33.SRB7.bin
PPCW_R76_501#sh ip int brie
Serial2/0/0:0 unassigned YES unset administratively down down
Serial2/0/1:0 10.18.0.125 YES manual administratively down down
Serial2/0/2:0 unassigned YES unset administratively down down
Serial2/0/3:0 unassigned YES unset administratively down down
Serial2/0/4:0 unassigned YES unset administratively down down
Serial2/0/5:0 unassigned YES unset administratively down down
Serial2/0/6:0 unassigned YES unset administratively down down
Serial2/0/7:0 unassigned YES unset administratively down down
I can configure descriptions/IP addresses on the ports, but am concerned these wont work when connected given the status of unknown - will this still work? Is there something else that needs to be configured/tested??
Phil
Solved! Go to Solution.
07-07-2010 08:31 AM
Phil, the SIP needs to be reset and then the test will be run. I was able to reproduce the behavior you saw. Even if you would have said yes to run the diagnostic the test wouldn't have run.
When I insert the SIP for the first time the card type isn't specified so the test is skipped:
*Jul 7 14:47:58.247: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
*Jul 7 14:48:30.091: %DIAG-SP-6-RUN_MINIMUM: Module 1/0: Running Minimal Diagnostics...
*Jul 7 14:48:30.295: SP: No port type is configured; the test is skipped for slot:1 bay:0.
Router#show diagnostic result mod 1/0
Current bootup diagnostic level: minimal
Module 1/0: 8xCHT1/E1 SPA SerialNo : JAE1242XPCG SerialNo : JAE1043E4TD
Overall Diagnostic Result for Module 1/0 : UNTESTED
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1) PortLoopbackTest:
Port 1 2 3 4 5 6 7 8
U U U U U U U U
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#card type e1 1 0
Router(config)#end
Router#
*Jul 7 14:49:49.839: %SYS-5-CONFIG_I: Configured from console by console
Router#
Here I try to force the test to run, but it still gets skipped and will only run at bootup:
Router#diagnostic start mod 1/0 test all
Diagnostic[Module 1/0]: Running test(s) 1 may disrupt normal system operation
Do you want to continue? [no]: y
Router#
*Jul 7 14:52:03.163: %DIAG-SP-6-TEST_RUNNING: Module 1/0: Running PortLoopbackTest{ID=1} ...
Router#
*Jul 7 14:52:03.175: SP: This test is valid only at bootup.
Router#
*Jul 7 14:52:03.175: %DIAG-SP-3-TEST_SKIPPED: Module 1/0: PortLoopbackTest{ID=1} is skipped
If we look at the show module output the SPA status is unknown as you saw:
Router#sh mod 1
1 0 4-subslot SPA Interface Processor-200 7600-SIP-200 JAE1043E4TD
1 0019.0656.e700 to 0019.0656.e73f 1.3 12.2(33)SRB7 12.2(33)SRB7 Ok
1/0 8xCHT1/E1 SPA SPA-8XCHT1/E1 JAE1242XPCG 1.5 Ok
1 Pass
1/0 Unknown
5 Pass
U U U U U U U U
Now if you reset the module the loopback test will be run:
Router#hw-module mod 1 reset
Proceed with reload of module?[confirm]
% reset issued for module 1
Router#
*Jul 7 14:53:07.527: %OIR-6-REMCARD: Card removed from slot 1, interfaces disabled
*Jul 7 14:53:07.519: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Reset)
*Jul 7 14:54:01.783: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 1/0
*Jul 7 14:54:01.787: %OIR-6-INSCARD: Card inserted in slot 1, interfaces administratively shut down
SLOT 1: *Mar 1 00:00:05.971: %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric ASIC 0 Channel 0: Fabric sync done.
*Jul 7 14:54:03.883: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
*Jul 7 14:54:04.243: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
*Jul 7 14:54:04.955: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
*Jul 7 14:54:36.751: %DIAG-SP-6-RUN_MINIMUM: Module 1/0: Running Minimal Diagnostics...
*Jul 7 14:55:16.059: %DIAG-SP-6-DIAG_OK: Module 1/0: Passed Online Diagnostics
We can verify the result is now pass:
Router#show mod 1
1 Pass
1/0 Pass
07-06-2010 03:00 PM
Phil,
Can you get the output from the following command for me:
show diagnostic result module 2/0
After that can you reload the SIP and see if you get a passing result?
07-07-2010 02:00 AM
MRCW_R76_352#sh diagnostic result module 2/0
Module 2/0: 8xCHT1/E1 SPA SerialNo : xxx SerialNo : xxx
D7Z4
Overall Diagnostic Result for Module 2/0 : UNTESTED
U U U U U U U U
I guess this means the module has not been tested yet....
MRCW_R76_352#diagnostic start module 2/0 test all
Diagnostic[Module 2/0]: Running test(s) 1 may disrupt normal system operation
I assume this command will cause impact to the router performance.
Phil
07-07-2010 04:24 AM
This specific SIP and SPA are Field Programmable Device which requires a special software Packages to be present in the flash. Pls check whether you downloaded the corresponding FPD for your IOS release and try this. I had this issue but after I did above everything was fine.
HTH...
thanks
Arun
07-07-2010 08:31 AM
U U U U U U U U
Router#conf t
Router(config)#end
Router#
Router#
Router#
Router#
Router#
Router#sh mod 1
1 Pass
1/0 Unknown
5 Pass
U U U U U U U U
Router#
Router#show mod 1
1 Pass
1/0 Pass
