IPS : HOST certificate issue...
Answered Question
Jul 2nd, 2010
Dear All,
I have doubt on host certificate:
I have two AIP-SSM module shows different host certificate value though i have installed/configured both on same date.
I am not very sure what this host certificate is.. could any1 help me to understand it.. and what is impect if it doesnt match...
IPS in Active ASA:
Host Certificate Valid from: 12-Jan-2009 to 13-Jan-2011
IPS in standby ASA:
Host Certificate Valid from: 04-Jun-2009 to 05-Jun-2011
Amar
Correct Answer by Scott Fringer about 6 years 9 months ago
Amar;
  The host certificate is used for establishing secure communication between the sensor and managing devices such as IPS Manager Express, CS-MARS, etc.  It can be re-generated from the CLI by issuing:
tls generate-key
  It will be valid for two years from the date it was generated.
Scott
Overall Rating: 4.5 (2 ratings)
Correct Answer
Scott Fringer Fri, 07/02/2010 - 11:14
  • Cisco Employee,
Amar;
tls generate-key
Scott
amardram123 Sat, 07/03/2010 - 01:32
Thanks scott,
Does it require any license or any other details to genrate... or i can simply issue the command "tls generate-key" and it will work...
Amar...
w-collazo Wed, 02/09/2011 - 05:31
Thanks. My problem started when i could no longer communicate to the sensor and IME was displaying "not connected" for one of my senors. I actually unistalled Cisco IME, Upgrade to version 7.0.3 and then notice i was getting an error in regards to the Certificate. I came across this forum and it solved my problem in a matter of seconds. Thanks.
Ricky Morales
