Deskphone disabled on CUPC release 8.x
Answered Question
Jul 2nd, 2010
Hello All,
We have a CUPS release 8 that runs fine on CUPC release 7.x. Yesterday we upgraded the CUPC client to 8.x and now the deskphone feature is greyed out. Chat and all other features are working except the deskphone.
When we test this with CUPC 7 it works at the same time with the same user accounts. Please assist on this.
When I check the Server health the notification is " failed to connect to ccmcip authentication server"
Is this related to the Deskphone ?
Is there any additional configuration that needs to be done on CUPS for CUPC 8.x other than what was done for CUPC 7.x
Correct Answer by htluo about 6 years 7 months ago
Per the log, your certificate on CUCM was expired.  You should regenerate the Tomcat cert.
1) Log into CUCM OS Administration page
2) Security > Certificate Management.  Click "Find" to list all certs.
3) Click on "tomcat.pem"
4) Click on "Regenerate"
5) On command line, type "utils service restart Cisco Tomcat"
Michael
Overall Rating: 3.5 (4 ratings)
abraham23482 Fri, 07/02/2010 - 23:50
Dear Mike,
I am sorry to say I did terminate this process but the same result. Only the Deskphone is still greyed out.. Do you see any other reasons why this is happening. The funniest part is CUPC 7 works so well with the same user ids..
htluo Sat, 07/03/2010 - 07:42
If CUPC7 works fine but CUPC8 doesn't, it has to be CCMCIP issue.  What error message you got on CUPC8?
Michael
abraham23482 Sat, 07/03/2010 - 08:11
The error message is
" Device initialization error has occured. Failed to connect to ccmcip authentication server [1201]"
I know there is something wrong with the CCMCIP settings but cant identify what and I am not sure if the CCMCIP settings that I gave was correct. Screenshot of CCMCIP settings was attached in the previous post.
Another point I noted is, In CUPC 7 also if I check the server health status the phone configuration is down. But still deskphone feature works in 7.x may be because it is failing over to a backup config residing locally.
htluo Sat, 07/03/2010 - 08:53
How did you get the report?  It should be a single big zip file on your desktop other than three small files.
Michael
htluo Sat, 07/03/2010 - 09:09
Per the log, it's still the CCMCIP certificate issue.
Could you export your registry hive HKEY_CURRENT_USER/Software/Cisco Systems, Inc./AdminData/ and upload here?
Thanks!
Michael
htluo Sat, 07/03/2010 - 09:21
Per the registry, you didn't follow my previous suggestion to set "CcmcipServerValidation" to "0".
In your registry, it's still "1":
Michael
abraham23482 Sat, 07/03/2010 - 09:29
Oops sorry about that. I had reverted the change last time when it was not working now again made it to 0 with no luck.
htluo Sat, 07/03/2010 - 09:32
Don't complicate the problem by keep changing settings.
Now with the value set to "0", do the following:
1) Kill cucsf.exe from Task Manager.
2) Recreate the problem.
3) Generate problem report
4) Upload Problem report and registry export again.
Michael
htluo Sat, 07/03/2010 - 10:10
There's no more CCMCIP cert error in the latest logs.
So what's the problem right now?
Michael
abraham23482 Sun, 07/04/2010 - 02:46
Attached is the screenshot with the status of the client. Somehow I am unable to get this thing working. However 7x client is working perfectly.
htluo Sun, 07/04/2010 - 06:53
It depends on WHEN you got that error.
Per the log, the last time of the CCMCIP error was:
Jul03_21:58:15 : Cannot validate CCMCIP HTTPS certificate (line 4564)
Did you get the error before or after Jul03_21:58:15?
Did you restart cucsf.exe after you change the registry?
The last CUPC session started at 2010-07-03 22:03:51.  But the log only contains the information up to 2010-07-03 22:04:00 (9 seconds since CUPC last restarted).  We won't be able to see too much info in 9 seconds.
You may do this:
1) Exit CUPC 8 and kill cucsf.exe.
2) Delete old logs in %userprofile%\Local Settings\Application Data\Cisco\Unified Communications\Client Services Framework\Logs
3) Make sure registry was set to 0
4) Lauch CUPC 8
5) Wait for at least 1 minute after logged in.
6) See if you can get the desk phone control
7) If not, generate problem report again.
Michael
abraham23482 Sun, 07/04/2010 - 09:37
I think I got the problem...
We edited the Registry value and made it 0 so that it ignores the certificate validation process. Now by doing this, we got the CUCIMOC to work. But the CUPC is still going for the certificate validation process.
Here's what I found from the logs of problem report.
2010-07-04 21:18:42,889 DEBUG [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPProviderImpl.fetchDeviceList(90)] - Attempting to connect to primary CCMCIP host: 172.22.16.10
2010-07-04 21:18:42,889 WARN  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(241)] - Unknown certification level, setting it to SELF_SIGNED_CERTS.  Unknown level value:
2010-07-04 21:18:42,889 INFO  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(244)] - Setting certification level to '1' (SELF_SIGNED_CERTS)
2010-07-04 21:18:42,905 ERROR [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(277)] - IOException: java.security.cert.CertificateExpiredException: NotAfter: Thu Jul 01 13:20:51 IST 2010
2010-07-04 21:18:42,905 INFO  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPProviderImpl.fetchDeviceList(117)] - Trying backup CCMCIP host: 172.22.16.10
2010-07-04 21:18:42,905 WARN  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(241)] - Unknown certification level, setting it to SELF_SIGNED_CERTS.  Unknown level value:
2010-07-04 21:18:42,905 INFO  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(244)] - Setting certification level to '1' (SELF_SIGNED_CERTS)
2010-07-04 21:18:42,905 ERROR [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPProviderImpl.fetchDeviceList(122)] - Couldn't connect to any CCMCIP host
2010-07-04 21:18:42,905 WARN  [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1533)] - Couldn't connect to any CCMCIP host. Sending async error.
2010-07-04 21:18:42,920 DEBUG [ws-pool-thread-2] [EventAdapter] [EventAdapterImpl.publish(140)] - publish method = onError class = com.cisco.uc.core.broker.phone.device.DeviceServiceCallback
2010-07-04 21:18:42,920 DEBUG [ws-pool-thread-2] [EventAdapter] [BaseClientProxy.publish(109)] - Adding callback to queue : onError priority message true
2010-07-04 21:18:42,920 WARN  [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1551)] - CCMCIP host is unreachable.  Trying to use the last used softphone device.
2010-07-04 21:18:42,920 ERROR [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.isSRSTConfigured(1642)] - Couldn't connect to any CCMCIP host and no softphone device is available.
2010-07-04 21:18:42,920 DEBUG [SOAPCallback - CcClient-1] [EventAdapter] [PendingCallbackQueue.poll(151)] - Taking callback from queue : onError primary queue size 0 secondary queue size 0
2010-07-04 21:18:42,920 ERROR [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1569)] - Couldn't connect to any CCMCIP host and no softphone device is available.
2010-07-04 21:18:42,920 DEBUG [SOAPCallback - CcClient-1] [EventAdapter] [SoapCallbackClientProxyImpl.processCallback(98)] - Notifying clientID CcClient-1 of onError on callback URL http://127.0.0.1:44442/v2/
2010-07-04 21:18:42,920 ERROR [ws-pool-thread-2] [DeviceAdapter] [DeviceServiceImpl.initialize(435)] - Problem initializing on the Device service. Could not connect to CCMCIP
com.cisco.uc.core.common.exceptions.device.CCMCIPFailureCoreException: Could not connect to CCMCIP
____________________________________________________________________________________________________
I am attaching the Admin Data Registry settings. Please refer this.
Abraham
htluo Sun, 07/04/2010 - 10:50
Did you install CUCIMOC and CUPC 8 on the same computer?  That is not supported.  Sorry I was confusing you with the word CUCIMOC while I acutally meant CUPC.
Could you upload CUPC problem report with registry set to 0?
Michael
abraham23482 Mon, 07/05/2010 - 00:22
I uninstalled everything that is related to CUCIMOC
Reinstalled the CUPC client 8.x
Restarted the Client PC
I have associated a softphone to the client and this works well with the same user id on a CUPC 7.x
Still the same problem that is the deskphone is disabled and I cannot make calls throught the client 8.x.
Attached is the problem report along with the registry settings. Please verify this.
Thanks in Advance
Abraham
abraham23482 Mon, 07/05/2010 - 01:52
I filtered the core log from the Problem report that I generated now. Please see this. In BOLD
2010-07-05 12:03:11,140 ERROR [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(277)] - IOException: java.security.cert.CertificateExpiredException: NotAfter: Thu Jul 01 13:20:51 IST 2010
2010-07-05 12:03:11,140 INFO  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPProviderImpl.fetchDeviceList(117)] - Trying backup CCMCIP host: 172.22.16.10
2010-07-05 12:03:11,140 WARN  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(241)] - Unknown certification level, setting it to SELF_SIGNED_CERTS.  Unknown level value:
2010-07-05 12:03:11,140 INFO  [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPClient.fetchDevices(244)] - Setting certification level to '1' (SELF_SIGNED_CERTS)
2010-07-05 12:03:11,140 ERROR [ws-pool-thread-2] [CCMCIPProvider] [CCMCIPProviderImpl.fetchDeviceList(122)] - Couldn't connect to any CCMCIP host
2010-07-05 12:03:11,140 WARN  [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1533)] - Couldn't connect to any CCMCIP host. Sending async error.
2010-07-05 12:03:11,156 DEBUG [ws-pool-thread-2] [EventAdapter] [EventAdapterImpl.publish(140)] - publish method = onError class = com.cisco.uc.core.broker.phone.device.DeviceServiceCallback
2010-07-05 12:03:11,156 DEBUG [ws-pool-thread-2] [EventAdapter] [BaseClientProxy.publish(109)] - Adding callback to queue : onError priority message true
2010-07-05 12:03:11,156 DEBUG [SOAPCallback - CcClient-1] [EventAdapter] [PendingCallbackQueue.poll(151)] - Taking callback from queue : onError primary queue size 0 secondary queue size 0
2010-07-05 12:03:11,156 WARN  [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1551)] - CCMCIP host is unreachable.  Trying to use the last used softphone device.
2010-07-05 12:03:11,156 DEBUG [SOAPCallback - CcClient-1] [EventAdapter] [SoapCallbackClientProxyImpl.processCallback(98)] - Notifying clientID CcClient-1 of onError on callback URL http://127.0.0.1:44442/v2/
2010-07-05 12:03:11,156 ERROR [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.isSRSTConfigured(1642)] - Couldn't connect to any CCMCIP host and no softphone device is available.
2010-07-05 12:03:11,156 ERROR [ws-pool-thread-2] [DeviceService] [DeviceServiceCoreImpl.populateCCMCIP(1569)] - Couldn't connect to any CCMCIP host and no softphone device is available.
2010-07-05 12:03:11,171 WARN  [SOAPCallback - CcClient-1] [DeviceService] [DeviceCallback.onError(242)] - OnError sent to the client.
Correct Answer
htluo Mon, 07/05/2010 - 07:25
Michael
abraham23482 Mon, 07/05/2010 - 11:41
Hi Mike,
Thank you so much. I did the changes you pointed out and it is working now.. All features are up and running fine and feels great to see the new client work in full swing.
thanks again.
Abraham
tenaro.gusatu.novici Tue, 07/06/2010 - 09:45
Hi there,
any chance you can share with us if softphone mode is working for you? I'm able to initiate calls from CUPC (which is then going to use my deskphone) but I'm not sure what to do so I can make calls directly from CUPC8, while I'm out-of-office.
Best regards,
Tenaro
abraham23482 Tue, 07/06/2010 - 10:58
I have a CUPC 8 client running fine with softphone now. Everything works perfect.
Are you sure you have mapped the softphone device to the user and associated the user to the softphone ?
pruttman Tue, 07/27/2010 - 09:28
How do you flip between softphone mode and deskphone modein CUPC 8?  I don't see the option like I do in CUPC 7.
Pete
benjaminwatt Tue, 07/27/2010 - 11:23
There's a tickbox at the bottom of CUPC 8 that will either say 'Use my desk phone for audio' or something like 'Use my Cisco 7971 for audio' depending on the model of Cisco phone you're using. When it's ticked you're in desk phone mode, when it's not you're in soft phone mode.
pruttman Tue, 07/27/2010 - 12:36
I see no checkbox, but it does say "User my Cisco 7960 for audio".  If I click on "cisco 7960" I get the Select Desk Phone Device" option, but no where do I see the ability to change to soft phone.
My phone is operating successfully in deskphone mode.
Pete
benjaminwatt Tue, 07/27/2010 - 13:05
There's probably other causes of this too, but the most likely explanation for this is that you haven't created a CSF (Cisco Unified Client Services Framework) phone device, and added it to the 'Controlled Devices' of that user.
CUPC 8 doesn't use the UPC (Cisco Unified Personal Communicator) type anymore as I understand it, so to get softphone functionality you need to create a CSF device for each user instead.
Desk phone control will work regardless of whether you have a CSF device or not.
abraham23482 Tue, 07/27/2010 - 15:09
Another thing I've noticed is, If I give 2 lines to my deskphone or softphone and associate that to my cups user ID, both the lines will display in the client but you cannot switch from one to the other. Wonder why then it is displayed there...
Abraham
pruttman Tue, 07/27/2010 - 15:20
I created a CSF device and a CCMCIP Profile and the checkbox appeared so I can now toggle between softphone and deskphone.  Thanks!
Pete
m.ranger Thu, 09/02/2010 - 08:29
Hello all,
I have the same problem, but not with all phones.
My setup is working with 8961 and 9971 Phones. All my Users are working with extension mobility and all of them have CUPC8.
For Users with a 8961 Phone and a Device Profil for 8961 Phones everything is working fine (Softphone Mode and Deskphone Mode).
For Users with a 9971 Phone and a Device Profil for 9971 Phones I have the same behaviour and the same error messages as descrived by Abraham23482.
I did the registry changes and recreated the tomcat.pem, but no change in the behaviour.
Attached my problem report.
Any ideas?
Best regards
Manfred
shamkumar Tue, 09/21/2010 - 11:14
Hi delete the presence dns which u created using UPCXXX(Cisco Unified Personal Communicator) in CUCM and create with CSFXXXX( Cisco Unified Client Services FrameWork) restart the CUPC client 8.x every thing will work now....deskphone controle and multiple deskphone controles......
upchaurasia Fri, 10/29/2010 - 05:43
I am facing some issues similar to this post and need expert help here. First let me explin my setup-
I have CUCM 8.x, CUPS 8.x and CUPC 8.0.171.
I have configured LDAP in CUCM and CUPS and created CUPC devices in CUCM and associated Cisco IP phone.
I am able to make call from my CUPC client but unable to initiate "Chat", when I click on "Chat" option I am getting "Invalid Parameter" error.
Otherthing I am able to search contact from my Microsoft AD. I have created LDAP profile in CUPS and able to import users from AD to CUCM and CUCM to CUPS. I am confused with the "Search Context" parameter in LDAP profile, what should I specify here.
I am attching logs.
Your suggestion will help me to move forward.
Thanks & Regards,
Umesh
