How can I turn DHCP back on?
Answered Question
Jul 2nd, 2010
I was able to turn DHCP off to give a demo to a customer now how do I turn it back on?
Correct Answer by Brandon Buffin about 6 years 9 months ago
In CCA, go to Configure > Routing > DHCP Server to create a new scope. Assuming you are using the UC500 for data and voice you will need a voice and data scope. You will also want to configure a range of exclusions for each scope - usually at least the first 10 addresses.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 07/02/2010 - 08:02
  • Purple, 4500 points or more
Hope this helps.
Brandon
