7204vxr port adapter for channelized STM1 ?
Jul 2nd, 2010
We need a DS3 in Italy. Our local provider says he can only deliver this on an STM1 optical, using a TUG3 of the STM1. Can we use a 7204 VXR STM1-router to terminate this, using a PA-POS-1OC3 ? or do we need to use another port adapter ?
Chetan Kumar Ress Fri, 07/02/2010 - 09:09
You can use the PA-POS-1OC3 for STM1 link in cisco 7204 VXR. In Cisco 7200 VXR routers, port adapter slots are numbered from the lower left to the upper right, beginning with port adapter slot 1 and continuing through port adapter slot 4 for the Cisco 7204VXR
For more detail : http://cisco.biz/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/pa-pos-1oc3_install_config/6514over.html#wp1039598
Note : Slot 1 is reserved for the supervisor engine. If a redundant supervisor engine is used, it must go in slot 2; otherwise, slot 2 can be used for other modules.
Chetan Kumar
