Can the 15454 perform Layer 2 switching on10GE Client Source.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Can the 15454 support a 10GE client source using Layer 2 Switching (Not RPR) at a Hub site to be distributing Ethernet to many collector nodes/rings over OC-12/48 links?
viyuan700 Fri, 07/02/2010 - 10:49
  • Silver, 250 points or more
There is no 10Gb ethernet card for 15454 which you want to take over OC 12/48 rings. (There are 10G cards for DWDM box).
As far as I know ethernet are point to point links means you have Ethernet interface at client side and in core network they go as T1/E1 and same speed on both client interface.
Let see you have 10G client ethernet at hub , how can you take a 10G on Oc12/48 Rings.
If it is broadcast 10G then also you need 10G client on other side not lower speed client.
Would you like to share what exactly you want to do?
Related Content
