BGP metric for Backup MPLS circuit
Answered Question
Jul 2nd, 2010
We have a 10 location fully-meshed MPLS network.  All CPE routers use the same AS number.  Two of the locations have backup MPLS circuit with the same ISP as the primary MPLS Circuit.  I've decided to use a basic route map to set the metric value of the backup circuit to a value of 10 .
One of the locations this configuration worked fine, but the other location i'm having problems.
Here is the configuation of the problem location
route-map Backup permit 10
set metric 10
router bgp 1
no synchronization
bgp log-neighbor-changes
network 172.20.114.0 mask 255.255.255.0
network 192.168.114.0
neighbor 1.1.1.1 remote-as 55000
neighbor 2.2.2.2 remote-as 55000
neighbor 2.2.2.2 route-map Backup in
neighbor 2.2.2.2 route-map Backup out
no auto-summary
When I do a "sh bgp"  the backup circuit isn't added in my remote network (which are ibgp), but it's added in the ISP router..
*> 192.168.107.0    1.1.1.1                         0 55000 55000 i                Remote Location Router
*> 192.168.109.0    1.1.1.1                         0 55000 55000 i                Remote Location Router
*  140.25.2.92/30            ISP Network
                    2.2.2.2           10             0 55000 ?
*>                  1.1.1.1                         0 55000 ?
*  132.11.15.220/30        ISP Network
From all the Routers, I can ping the backup circuit IP address that my ISP provided me (2.2.2.1 and 2.2.2.2).
When I bring down the primary circuit, I can't ping to any of my remote networks or ibgp networks.  Hopefully this makes a little since, I don't know much about BGP.
Correct Answer by Chetan Kumar Ress about 6 years 7 months ago
Hi Brain
You have to check the issue with you SP . Why you are not geting route from Backup circuit and till the time you can keep the static route.
And Fast convergence simply  you can reduce the holdtimer.
U can use this command
Router(config-router)# timers bgp keepalive holdtime
or even u can apply per neighbor,
Router(config-router)# neighbor [ip-address | peer-group-name] timers keepalive holdtime
Please refer the same post https://supportforums.cisco.com/thread/247105?tstart=0&viewcondensed
Chetan Kumar
Overall Rating: 5 (1 ratings)
Brian Smith Fri, 07/02/2010 - 21:44
Thanks for the reply,
I configured a weight attribute for the primary and secondary links.  Looks like the higher weight will be the preferred router.
When I failover to the secondary circuit I still don't have any of my ibgp networks in the routing table, only the ISP networks.
Something must be configured wrong with the ISP router.  I configure a default route with a admin. distance of 200 (ip route 0.0.0.0 0.0.0.0 2.2.2.2 200)
With the route i'm able to ping my remote routers, but the convergence time takes about 3 mins. Is there a way to shorten that time? .
Brian Smith Sat, 07/03/2010 - 20:53
Can I implement RTR or BFD without contacting the Service Provider? Or do I need to contact the SP so they can make a configuration change in their routers?
Chetan Kumar Ress Tue, 07/06/2010 - 11:59
Hi Brain
As i suggest you to discussed the same issue with SP to get resolution ASAP.
Regrads
Chetan Kumar
amar_5664 Mon, 07/05/2010 - 17:50
hey brian,
it should have nothing to do with SP, can you post configs of your router. how are you running ibgp do you have any IGP?
on your router could you do
sh ip bgp nei received-routes
sh ip bgp nei received- routes
sh ip bgp summ
sh ip bgp nei <> adv- routes
and post it here please...
amar_5664 Mon, 07/05/2010 - 17:40
chetan the highest weight will be preferred ... so it should be the other way round...
router bgp xxxx
no synchronization
neighbor x.x.x.x remote-as xxxx
neighbor x.x.x.x weight 150 ------  Secondary
neighbor x.x.x.x weight 180 ------  Primary
no auto-summary
Chetan Kumar Ress Tue, 07/06/2010 - 11:56
Hi Amar
Yes , Due to some work i was not able to review the post , So by mistake it happen.
I Realy apologize for that post. I had made the changes.
Chetan kumar
vdineshkumar83 Tue, 07/06/2010 - 02:50
Hi Brain,
         It seems you are using same AS throughout your domain which requires AS-override or allow-AS-in  at service provider end to bring up the circuit. Since you are saying with primary links you are not seeing any issues may be at PE(service provider end) where the secondary link is terminated might not have the above said command. Do check with your SP. Hope this helps.
V Dinesh Kumar
Brian Smith Tue, 07/06/2010 - 14:05
Thanks for all the post.  It's been helpfull.   I'm still a bit confused with a couple of things, I hope I can explain this well.
Here is my BGP config.  I'm running is BGP, using iBGP to exchange my internal networks, all the routers use bgp AS 1.  (NO IGP).  Two MPLS circuits (Same SP), using a weighted attribute for primary and secondary links.
Below is a "SH BGP" output.  My iBGP networks (192.168.100.0/24, 192.168.101.0/24, etc) do not have the backup circuit in the bgp table, just the primary circuit.   When I tested this by shutting down the interface of the primary circuit, I couldn't get to any of my internal network because they were not in the routing table, only the Service Provider networks were in the routing table.  I create a static route (ip route 0.0.0.0 0.0.0.0 195.22.4.41 200)  Once I added the static route I was able to ping my internal networks, but the converence time was about 3 mins.
My questions are:
I'm wondering why the iBGP networks do not have the backup circuit in it's bgp table?  (I'm assuming the service provider router is configured incorrectly)  Should I get the SP to fix this or keep the static route?)
How can I shorten the converence time without getting the service provider involved?  Earlier posts sugguested a couple of things but I'm not sure what would work best.  Would BGP fast-peering work in this case?
router bgp 1
no synchronization
network 10.0.8.2 mask 255.255.255.255        Loopback
network 172.20.5.0 mask 255.255.255.0
network 192.168.5.0
neighbor 152.17.9.202 remote-as 65000
neighbor 152.17.9.202 weight 100
neighbor 195.22.4.41 remote-as 65000
neighbor 195.22.4.41 weight 50                    Backup Circuit
no auto-summary
sh bgp
*> 122.1.162.68/30 152.17.9.202                       100 65000 ?          SP Network
*                             195.22.4.41                         50 65000 ?          BACKUP CIRCUIT
*> 122.6.22.14/30
*> 154.153.112.40/30
*> 192.168.100.0    152.17.9.202                    100 65000 65000 i
*> 192.168.101.0    152.17.9.202                     100 65000 65000 i
*> 192.168.102.0    152.17.9.202                      100 65000 65000 i
*> 192.168.104.0    152.17.9.202                      100 65000 65000 i
Correct Answer
Chetan Kumar Ress Tue, 07/06/2010 - 14:29
Hi Brain
Chetan Kumar
amar_5664 Wed, 07/07/2010 - 02:22
hey mate,
according to your config i dont see ibgp peering, your neighbour commands only point to your SP AS. So probably your network is not being propogated via ibgp.
could you please do sh ip bgp summ and paste it here?
Brian Smith Wed, 07/07/2010 - 20:38
I thought since all my routers are in the same AS number
that it's using iBGP.
below is the output of sh ip bgp sum
BGP router identifier 10.0.8.2, local AS number 1
BGP table version is 877, main routing table version 877
117 network entries using 15444 bytes of memory
144 path entries using 7488 bytes of memory
8/7 BGP path/bestpath attribute entries using 1184 bytes of memory
4 BGP AS-PATH entries using 96 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 2) using 32 bytes of memory
BGP using 24244 total bytes of memory
BGP activity 1083/966 prefixes, 2138/1994 paths, scan interval 60 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
12.1.8.21  4 65000   34022   37238      877    0    0 4d23h         112
19.211.41.5   4 65000    6606    7251      877    0    0 4d23h          27
Brian Smith Thu, 07/08/2010 - 06:13
added the following to the bgp config
timers bgp 10 30
The converence time is pretty good when I tested it.
CPU utilization is around 37%
Chetan Kumar Ress Thu, 07/08/2010 - 08:35
Hi Brian
As in previous post i told you to have a word with you SP & Now your convergence issue resolved as told to manipulate  keepalive & holdtimer.
In your below output you can see that you are receving 112 prefix from 12.1.8.21 (State/PfxRcd) & 27 prefix from 19.211.41.5.
Sh ip sh ip bgp table you can see the prefix that you are receving from both MPLS Circuit. As per your network if you think that you should receive all route from bith MPLS circuit then you should have a word with you SP that why you r not getting all prefix from both circuit.
Chetan Kumar
Chetan Kumar Ress Fri, 07/02/2010 - 09:19
As per my understanding you have two MPLS link from Same SP. And you want to configure Primary & Secondary link.
So simply you can configure Weight on that router to select Primary & Secondary .
And you can inform the same to ISP
For Example : Location Conifg.
router bgp xxxx
no synchronization
no auto-summary
So you inbound traffic will prefer Primary link.
Chetna kumar
