ccarring Fri, 07/09/2010 - 10:28
Are you using ssh on the vty lines, and IOS lower than 12.2(25)SE? If so, you may be running into a know bug
The CNA RElease Notes here ( http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp710973  ) refer to a workaround:
Network Assistant fails  when a device is running the cryptographic software image and the vty  lines have been configured with the transport input ssh and line vty 0 15 global configuration commands  only use SSH.
The workaround is to use the transport input ssh telnet and line vty 0 15 global configuration commands to  allow SSH and Telnet access through the vty lines. After you upgrade to  Cisco IOS 12.2(25)SE or higher, you can enable http or https separately  from Telnet. (CSCdz01037)
If that does not help... let us know the device and version, the version of CNA, and what configuration the device has fot http, https, telnet, and ssh.
Curtis
