Can RME backup ASA SSL VPN Configurations?
Jul 2nd, 2010
Within ASDM you can backup all configuration items, including SSL VPN configurations like bookmarks, DAP, etc.  Is Ciscoworks RME capable of archiving the same configurations?  If not, will it be available in Ciscoworks LMS 4.0?
Joe Clarke Mon, 07/05/2010 - 12:46
When RME archives the configuration from an ASA, it connects to the device via telnet or SSH, then runs "show running".  If the items you want are stored in the running config, then RME will archive them.  If not, then they will not be collected.  I have not seen any change to this behavior in the 4.0 beta.
