07-02-2010 11:08 AM - edited 03-06-2019 11:53 AM
I'm having some trouble with establishing a trunk port between a Cisco 6513 and Cisco 4948.
Here is the config:
Cisco 6513
int gig 8/1
switchport
switchport encap dot1q
switchport mode trunk
switchport trunk allowed vlan 1
speed noneg
no shut
int vlan 1
description Mgmt VLAN
ip address 10.10.10.1 255.255.255.0
no shut
Cisco 4948
gig 1/48
switchport
speed noneg
no shut
int vlan 1
ip address 10.10.10.2 255.255.255.0
no shut
Status:
1- Both Gige's are up/up
2- But can't ping each other
Cards on Cisco 6513:
slot:7 2 Supervisor Engine 720 (Active) WS-SUP720-3B
Slot:8 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
I have Gig7/1 on Cisco 6513 and Gi1/47 on the Cisco 4948 up, as a routed port. I hate to touch these ports or else I loose connectivity to the Cisco 4948.
-Manny
07-02-2010 12:16 PM
Manny,
Can you provide from both 6513 and 4948 switches the output of " show int gig8/1 switchport " and "show int gig1/48 switchport" , also output of "show interface gig8/1 trunk" , show int gig1/48 trunk from the 4948 .
you may need to use " switchport trunk encap dot1q" in the interfaces , unless switchport encap dot1q syntax is a typo or command was introduce in a ios version Im not aware of then is fine, but the output of above interface information as well as "show vtp status" from each switch would help to understand your l2 topology and give us some hints on what could be the issue on the interfaces
07-03-2010 09:57 PM
Can I ask you something ? Isnt is that the port are working as switchports ( trunk mode ) and you are assigning Ip address on that switchport and trying to ping them. I think ones the port is in switching mode the ip address is assigned to the SVI and then you can access the switch using that SVI ip address. It is always the routed port that are assigned the ip address.
Let me know if my understanding of switchports and routed ports are wrong !! plz
Manish
07-03-2010 10:00 PM
sorry ! misread it the first time , drunk i believe ... did not see the interface vlan config. can you post
1> sh ip route
2> sh spanning tree
3> Vlan database
Manish
07-06-2010 08:03 AM
Cisco 4948- sho run int gig 1/47 interface GigabitEthernet1/47 description to Cisco 6515 – Gi7/1 ip address 20.20.20.1 255.255.255.252 speed nonegotiate end
show run int gig 1/48 interface GigabitEthernet1/48 description to Cisco 6515 - Gi8/1 switchport trunk encapsulation dot1q switchport mode trunk shutdown speed nonegotiate end
show int gig 1/48 GigabitEthernet1/48 is up, line protocol is up (connected) Hardware is Gigabit Ethernet Port, address is 001a.6d2e.25ef (bia 001a.6d2e.25ef) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLH Media-type configured as SFP connector input flow-control is on, output flow-control is off ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 7000 bits/sec, 7 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 52743 packets input, 4514048 bytes, 0 no buffer Received 50864 broadcasts (19152 multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 384 packets output, 62066 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
show run int vlan 1 interface Vlan1 ip address 172.22.100.28 255.255.255.0 end
ping 172.22.100.23 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.22.100.23, timeout is 2 seconds: ..... Success rate is 0 percent (0/5)
show ip ro Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.22.100.1 to network 0.0.0.0
20.0.0.0/30 is subnetted, 1 subnets C 20.20.20.0 is directly connected, GigabitEthernet1/47 172.22.0.0/24 is subnetted, 1 subnets C 172.22.100.0 is directly connected, Vlan1 S* 0.0.0.0/0 [1/0] via 172.22.100.1
show spanning-tree VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 32768 Address 0006.282b.7680 Cost 23 Port 48 (GigabitEthernet1/48) Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1) Address 001a.6d2e.25c0 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300
Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi1/48 Root FWD 4 128.48 P2p
show int vlan 1 Vlan1 is up, line protocol is up Hardware is Ethernet SVI, address is 001a.6d2e.25ff (bia 001a.6d2e.25ff) Internet address is 172.22.100.28/24 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:07, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes 639 packets input, 260024 bytes, 0 no buffer Received 639 broadcasts (0 IP multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 120 packets output, 6330 bytes, 0 underruns 0 output errors, 0 interface resets 0 output buffer failures, 0 output buffers swapped out
show cdp neighbors Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID Cisco 6515 Gig 1/48 130 R S I WS-C6513 Gig 8/1 Cisco 6515 Gig 1/47 161 R S I WS-C6513 Gig 7/1
| Cisco 6515- show run int gig 8/1 interface GigabitEthernet8/1 description to Cisco 4948 - Gi1/48 switchport switchport trunk encapsulation dot1q switchport mode trunk speed nonegotiate end
show run int gig 7/1 interface GigabitEthernet7/1 description to Cisco 4948 - Gi1/47 ip address 20.20.20.2 255.255.255.252 speed nonegotiate
show int gig 8/1 GigabitEthernet8/1 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 0013.7f0d.3ce4 (bia 0013.7f0d.3ce4) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is LH input flow-control is off, output flow-control is on Clock mode is auto ARP type: ARPA, ARP Timeout 04:00:00 Last input 3d22h, output 00:00:07, output hang never Last clearing of "show interface" counters 29w5d Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 555 packets input, 89894 bytes, 0 no buffer Received 505 broadcasts (500 multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 52504 packets output, 4595486 bytes, 0 underruns 0 output errors, 0 collisions, 3 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out
show run int vlan 1 interface Vlan1 ip address 172.22.100.23 255.255.255.0 end
ping 172.22.100.28 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.22.100.28, timeout is 2 seconds: ..... Success rate is 0 percent (0/5)
show ip route Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
20.0.0.0/30 is subnetted, 1 subnets C 20.20.20.0 is directly connected, GigabitEthernet7/1 172.22.0.0/24 is subnetted, 1 subnets C 172.22.100.0 is directly connected, Vlan1 S* 0.0.0.0/0 [1/0] via 172.22.100.1
show spanning-tree VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 32768 Address 0006.282b.7680 Cost 19 Port 176 (FastEthernet2/48) Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1) Address 000b.60f3.ab80 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300
Interface Role Sts Cost Prio.Nbr Type ------------------- ---- --- --------- -------- -------------------------------- Fa2/48 Root FWD 19 128.176 P2p Gi4/3 Desg FWD 4 128.387 P2p Gi8/1 Desg FWD 4 128.897 P2p Po4 Desg FWD 4 128.1665 P2p Po5 Desg FWD 4 128.1666 P2p
Device ID Local Intrfce Holdtme Capability Platform Port ID Cisco 4948 Gig 8/1 179 R S I WS-C4948 Gig 1/48 Cisco 4948 Gig 7/1 167 R S I WS-C4948 Gig 1/47
show int vlan 1 Vlan1 is up, line protocol is up Hardware is EtherSVI, address is 000b.60f3.ab80 (bia 000b.60f3.ab80) Internet address is 172.22.100.23/24 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive not supported ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 29w5d Input queue: 0/75/751936/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 2000 bits/sec, 4 packets/sec 5 minute output rate 3000 bits/sec, 3 packets/sec L2 Switched: ucast: 1679904971 pkt, 1055602240049 bytes - mcast: 40919877 pkt, 3222830684 bytes L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast L3 out Switched: ucast: 26171 pkt, 2162109 bytes mcast: 0 pkt, 0 bytes 40688097 packets input, 3317459000 bytes, 0 no buffer Received 40170596 broadcasts (29217 IP multicasts) 0 runts, 0 giants, 3352 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 532795 packets output, 158199679 bytes, 0 underruns 0 output errors, 0 interface resets 0 output buffer failures, 0 output buffers swapped out
07-06-2010 09:17 AM
Fiber
Something is not right. The 'sh run' shows interface g1/48 as 'shutdown', but the 'sh int g1/48' shows it up/up.
Can you verify that it isn't shutdown.
07-06-2010 09:21 AM
Can you also post the 'show interface trunk' output ?
07-06-2010 10:08 AM
I dont have much experience with the Cisco 6515, can Gig8/1 on the Cisco 6515 be on-standby since its the standy card? Card in slot 7 is active. I figured Gig8/1 can not be used, but I maybe wrong.
Cisco 4948
show int gig 1/47 GigabitEthernet1/47 is up, line protocol is up (connected) Hardware is Gigabit Ethernet Port, address is 001a.6d2e.25ff (bia 001a.6d2e.25ff) Description: to Cisco 6515 - Gi7/1 Internet address is 20.20.20.1/30 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLH Media-type configured as SFP connector input flow-control is on, output flow-control is off ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 1000 bits/sec, 1 packets/sec L3 in Switched: ucast: 2224 pkt, 92157 bytes - mcast: 0 pkt, 0 bytes L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes 213212 packets input, 20240692 bytes, 0 no buffer Received 207575 broadcasts (0 IP multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 13762 packets output, 4526996 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
show int gig 1/48 GigabitEthernet1/48 is up, line protocol is up (connected) Hardware is Gigabit Ethernet Port, address is 001a.6d2e.25ef (bia 001a.6d2e.25ef) Description: to Cisco 6515 - Gi8/1 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLH Media-type configured as SFP connector input flow-control is on, output flow-control is off ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 18000 bits/sec, 21 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 70401 packets input, 5868701 bytes, 0 no buffer Received 67842 broadcasts (32571 multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 430 packets output, 67334 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
show int trunk Port Mode Encapsulation Status Native vlan Gi1/48 on 802.1q trunking 1
Port Vlans allowed on trunk Gi1/48 1-4094
Port Vlans allowed and active in management domain Gi1/48 1
Port Vlans in spanning tree forwarding state and not pruned Gi1/48 1
| Cisco 6515
show int gig 7/1 GigabitEthernet7/1 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 000b.60f3.ab80 (bia 000b.60f3.ab80) Description: to Cisco 4948 - Gi1/47 Internet address is 20.20.20.2/30 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is LH input flow-control is off, output flow-control is on Clock mode is auto ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:20, output 00:00:20, output hang never Last clearing of "show interface" counters 29w5d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec L2 Switched: ucast: 1886 pkt, 181338 bytes - mcast: 5 pkt, 335 bytes L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes 14198 packets input, 4577862 bytes, 0 no buffer Received 12121 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 223015 packets output, 21303395 bytes, 0 underruns 0 output errors, 0 collisions, 5 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out
show int gig 8/1 GigabitEthernet8/1 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 0013.7f0d.3ce4 (bia 0013.7f0d.3ce4) Description: to Cisco 4948 - Gi1/48 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is LH input flow-control is off, output flow-control is on Clock mode is auto ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:42, output 00:00:44, output hang never Last clearing of "show interface" counters 29w5d Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 17000 bits/sec, 20 packets/sec 606 packets input, 95814 bytes, 0 no buffer Received 534 broadcasts (529 multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 72853 packets output, 6150090 bytes, 0 underruns 0 output errors, 0 collisions, 3 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out
show int trunk Port Mode Encapsulation Status Native vlan Gi4/3 on 802.1q trunking 1 Gi8/1 on 802.1q trunking 1 Po4 on 802.1q trunking 1 Po5 on 802.1q trunking 1
Port Vlans allowed on trunk Gi4/3 1,328-348 Gi8/1 1-4094 Po4 1,300-499,600-699 Po5 1,300-499,600-699
Port Vlans allowed and active in management domain Gi4/3 1,328-348 Gi8/1 1,149,301-349,401-406 Po4 1,301-349,401-406 Po5 1,301-349,401-406
Port Vlans in spanning tree forwarding state and not pruned Gi4/3 1,328-348 Gi8/1 1,149,301-349,401-406 Po4 1,301-349,401-406
Port Vlans in spanning tree forwarding state and not pruned Po5 1,301-349,401-406
